هاك ماسنجر المنتدى الشبيه بـ FaceBook
??? ?????? ??? ???? ??? ??????? 0.4.3 ????? ?? ?? ?? ??? ?? ?? ???? ????
?? ??? ???? ????? im_install.php ??????? ??? ?? ??????? ?????
http://www.shababalsahel.com/phpBB/index.php
?? ????? ??? ??????? ?????? ??????? . ??? ????????? ????? ????? ?? ????? !MathsMak كتب:?????? ?? ?? ????? ??? ?????? ?? ???????? ????????
? ??? ?? ???? ?????? ?????? ???????? , ??? ???? ?? ??? 2010 ?????????
???? ??????? ????????? ???? ???????? ???? ?????A.B.M.K كتب:?? ????? ??? ??????? ?????? ??????? . ??? ????????? ????? ????? ?? ????? !MathsMak كتب:?????? ?? ?? ????? ??? ?????? ?? ???????? ????????
?????? ?????? http://www.shababalsahel.com/p
- Ali_Saad_Ali
- عضو متميز
- مشاركات: 258
- اشترك في: الجمعة سبتمبر 24, 2004 9:26 pm
?? ... ?? ???? ???Ali_Saad_Ali كتب:?? ???? ???? ?????? ??? ? ???? ???? ???? ???????? ????? ??? ??
: styles/subsilver2/template/memberlist_body.html
?????? ???? 3.0.8 ??? ????? ?????? ???????
<td class="row1" colspan="<!-- IF S_IN_SEARCH_POPUP -->9<!-- ELSE -->8<!-- ENDIF -->" align="center">
<td class="cat" colspan="<!-- IF S_IN_SEARCH_POPUP -->9<!-- ELSE -->8<!-- ENDIF -->" align="center"><!-- IF S_IN_SEARCH_POPUP and not S_SELECT_SINGLE --><input class="btnlite" type="submit" value="{L_SELECT_MARKED}" /><!-- ELSE --><span class="gensmall">{L_SELECT_SORT_METHOD}:</span> <select name="sk">{S_MODE_SELECT}</select> <span class="gensmall">{L_ORDER}</span> <select name="sd">{S_ORDER_SELECT}</select> <input type="submit" name="submit" value="{L_SUBMIT}" class="btnlite" /><!-- ENDIF --></td>
???????????? Atramez_Zeton ?? ???????? ????? 15, 2010 5:43 pm
???:Unknown table 'F'
DROP TABLE F;
DROP TABLE F;
SQL ERROR [ mysqli ]
Table 'sm_phpbb308.USERS_IM_TABLE' doesn't exist [1146]
SQL
SELECT user_deny_im, user_status FROM USERS_IM_TABLE WHERE user_id = 2
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
FILE: includes/hooks/hook_instant_messenger.php
LINE: 31
CALL: dbal_mysqli->sql_query()
FILE:
LINE:
CALL: im_extend_user_data()
FILE: includes/hooks/index.php
LINE: 141
CALL: call_user_func_array()
FILE: includes/functions.php
LINE: 4749
CALL: phpbb_hook->call_hook()
FILE: includes/session.php
LINE: 1806
CALL: phpbb_user_session_handler()
FILE: index.php
LINE: 36
CALL: user->setup()
DROP TABLE F;
DROP TABLE F;
??? ???? ??? im_install ??? ????? ?? ????? ???????? ? ???? ??? ????? ??????? ????
??? ??? ????? ???? ??? install.xml ????? ?? ????? ???? ?? ???? ??????? ????? ???????? , ??? ???? ???? ?? ????
