[هاك] تسجيل في المنتدى باستخدام الفيس بوك
??? ?? ???? ?? ?????? , ?? ???????? test.php . ??? ??????? ??? ????? ?????? ? ???? ?? ??? ??????? , ???? ????? ?? ????? ?? ???? ??? ????? !
???? ???? ??? ???????? ? ??? ??? ?????? ?? ??????? ??? ??????? ! ? ???? ?? ???? ?? ?????? ???????Update! The dl file now includes a test.php file for you to load to your phpbb root folder. Upload it, and visit it in your browser! If it tells you that there's a problem with your host/server... do not bother installing this hook until the issue is corrected! Once corrected, revisit this file to have it correct the config table to indicate compatibility.
If your host restricts or has disabled the use of fgc/curl, the hook will not be able to retrieve data from Facebook. Working around this with javascript is a security nightmare, so it has not nor will not be done! 99% of issues that arose on initial beta release of this hook stemmed from host issues. The hook now contains a check internally to ensure it can retrieve data from facebook, and if not will disable itself. Do not attempt to 'force' the hook past this check.
- عاصم المهدي
- عضو متميز
- مشاركات: 232
- مكان: USA
- عاصم المهدي
- عضو متميز
- مشاركات: 232
- مكان: USA
????? ??? ?? ??? ?? ????? ???????? ? ?? ???? ????? ????? ????? ? ???? ??? ????? ????? ????????? ???????? ?????? ?????? ??? ???? ??? ?????? ???????? ?? ??? ????? ??? ??? ????? ? ???? ?? ?? ????? ?? ?????? ?? ?????? ??????? ??????? ???? ???? ???? ?? ???? ??????? ??? ?????? ?????? ???? ??? ??? ???? ????? ??????? ?? ???? ????? ??? ????? ??????? ????????? ??????? ??? ?? ??? ??? ????? ??? ????? ??A.B.M.K كتب:??? ??? ???? ?????? ????? ????? ????? , ?? ?????? ?????? ????? ??? ?? ????? ?? ???????? ! ??????? ????????? ??? ?????? ??? ??? ????? ??????
- عاصم المهدي
- عضو متميز
- مشاركات: 232
- مكان: USA
?? A.B.M.K ???? ?? ??? ?
??? ??? ??? ??? ????? ???? test.php ???? ?? ?? ??? ??????
?[phpBB Debug] PHP Notice: in file /test.php on line 43: file_get_contents(https://graph.facebook.com/me/) [function.file-get-contents]: failed to open stream: Invalid argument
Warning: Cannot modify header information - headers already sent by (output started at C:\AppServ\www\phpBB3\includes\functions.php:3706) in C:\AppServ\www\phpBB3\includes\functions.php on line 4505
Warning: Cannot modify header information - headers already sent by (output started at C:\AppServ\www\phpBB3\includes\functions.php:3706) in C:\AppServ\www\phpBB3\includes\functions.php on line 4507
Warning: Cannot modify header information - headers already sent by (output started at C:\AppServ\www\phpBB3\includes\functions.php:3706) in C:\AppServ\www\phpBB3\includes\functions.php on line 4508
Warning: Cannot modify header information - headers already sent by (output started at C:\AppServ\www\phpBB3\includes\functions.php:3706) in C:\AppServ\www\phpBB3\includes\functions.php on line 4509
?? Your server failed to retrieve data from facebook.
It appears incompatible with this hook/mod. If you have already uploaded the hook_svmods_facebook_connect.php file, please delete it and purge your cache from the ACP.
???? ?? ???? ???? ?? ???? ???? appserv-win32-2.5.9
???? ??? test.php ??? ?? ???? ??????? ??????? ???????
Congratulations!
It looks like your server should work fine with this hook.
You may proceed with installation.
???? ???? ??????__________ ???________??????? ??????? ???? ?? ???? ?? ?? ??? ????? ??? ???? ??? ?????? ???????? ???????? ???? ???? ???????? ?????
???? ?????? www.shababalsahel.com/forum
Congratulations!
http://www.shababalsahel.com/forum/ucp.php?mode=login
???? ??????? ???? ????? ??? godaddy.com
www.abusada.net/vb
????? ??????? ?? ????? ??? ???????Fatal error: Call to undefined function: curl_multi_init() in /home/content/m/u/r/murad1965/html/vb/includes/hooks/hook_svmods_facebook_connect.php on line 199
www.abusada.net/vb
????? ????? ?? ??? functions.phpFatal error: Call to undefined function: curl_multi_init() in /home/content/m/u/r/murad1965/html/vb/includes/hooks/hook_svmods_facebook_connect.php on line 199
