[RC5] هاك الإهداءات Top presentation
[RC5] ??? ????????? Top presentation
eman80 كتب:??? ??? ?????? ????? ????? ???? ????? ???:
?? ?????? ?? ??? ?????????? ???????? ?? ????????? ???????? ? ??? IE7 ???? ???? ??? ???? ?? ???? ????????? ??? ?????????? ?? ???? ???? ????????? ???? .. ??? ??? ??????? ??????.
?????? ?? ?????: includes/function_pts.php
'TEXT' => addslashes($text)كود: تحديد الكل
'TEXT' => ($type_show_tp == 'ver' && !$auth->acl_get('a_')) ? addslashes($text) : $text????? ?? saanina
- ebrimnubian
- مشاركات: 55
- اشترك في: الجمعة إبريل 04, 2008 3:22 pm
u????? ????? ????? ????? ?? ???? ????? ???????? ???? ?? ??? ???????
???:Table 'phpbb_present' already exists
CREATE TABLE `phpbb_present` ( `id` int(11) NOT NULL auto_increment, `userid` int(8) NOT NULL, `username` varchar(255) character set utf8 collate utf8_bin NOT NULL, `usercolor` varchar(6) character set utf8 collate utf8_bin NOT NULL, `time` int(11) NOT NULL, `text` varchar(255) character set utf8 collate utf8_bin NOT NULL, `show_or_no` tinyint(1) NOT NULL default '0', PRIMARY KEY (`id`) )CHARACTER SET `utf8` COLLATE `utf8_bin`
???:Duplicate entry 'limit_pts' for key 1
INSERT INTO phpbb_config (config_name, config_value) VALUES ('limit_pts', '40')
???:Duplicate entry 'no_visitor_pts' for key 1
INSERT INTO phpbb_config (config_name, config_value) VALUES ('no_visitor_pts', '1')
???:Duplicate entry 'day_before_del_pts' for key 1
INSERT INTO phpbb_config (config_name, config_value) VALUES ('day_before_del_pts', '3')
???:Duplicate entry 'type_show_pts' for key 1
INSERT INTO phpbb_config (config_name, config_value) VALUES ('type_show_pts', 'hor')
???:Duplicate entry 'show_all_pts' for key 1
INSERT INTO phpbb_config (config_name, config_value) VALUES ('show_all_pts', '0')
???:Duplicate entry 'safty_code_pts' for key 1
INSERT INTO phpbb_config (config_name, config_value) VALUES ('safty_code_pts', '0')
اسم المنتدى:www.ebrimnubian.com/phpbb3
نوع الأستايل المستخدم:subsilver
- ebrimnubian
- مشاركات: 55
