هاك اضافة ازرار الى قائمة Buttons menu
??? ????? ????? ??? ????? Buttons menu
?? ???? ???? ????? ??? span ?????? div
??? ?? ????? ????? ???? ?????? ??div ??? ??? ???? ?????? ??????? ..
<div class="headerbar">
<div class="inner"><span class="corners-top"><span></span></span?? ???? ???? ????? ??? span ?????? div
<div class="inner"><span class="corners-top"><span></span></span></div>??? ??????? ..
SQL ERROR [ mysql4 ]
Table 'almiad_bbfor380.MENU_TABLE' doesn't exist [1146]
SQL
SELECT button_id, button_url, button_name, button_target FROM MENU_TABLE WHERE button_id >= 1 ORDER BY button_id LIMIT 6
BACKTRACE
FILE: includes/db/mysql.php
LINE: 175
CALL: dbal->sql_error()
LINE: 222
CALL: dbal_mysql->sql_query()
FILE: includes/db/dbal.php
LINE: 170
CALL: dbal_mysql->_sql_query_limit()
FILE: includes/acp/acp_menu.php
LINE: 74
CALL: dbal->sql_query_limit()
FILE: includes/functions_module.php
LINE: 507
CALL: acp_menu->main()
FILE: adm/index.php
LINE: 74
CALL: p_master->load_active()
SQL
BACKTRACE
LINE: 175
LINE: 222
LINE: 170
LINE: 74
LINE: 507
FILE: adm/index.php
LINE: 74
http://www.al-yemen.de/mods/index.php
<!-- IF S_DISPLAY_SEARCH and not S_IN_SEARCH -->كود: تحديد الكل
<!-- IF ( S_DISPLAY_SEARCH and not S_IN_SEARCH ) and not ( S_MENU_ENABLED and S_MENU_SEARCH ) -->??? ???? ???????
??? ???? ?? ??????? ?? overal_header.html
????? ??? ????? ??? ????? ?????? ??? ????A.B.M.K كتب:????? ??? ??????? , ?? ??? ????? ????? ? ??? ???????? ????? ??? ???? ??? ??? ?? ???? ????????
<!-- IF S_MENU_ENABLED -->
<span class="corners-bottom" style="height:0px;"><span></span></span></div>
<div id="menu" style="clear:both;<!-- IF S_MENU_MARGIN -->margin-top: -3px;<!-- ELSE -->margin-top: -4px;<!-- ENDIF -->;background: url('{T_THEME_PATH}/images/menu/{S_MENU_COLOR}/menu_bg.gif') repeat-x;">
<div class="inner">
<span class="menu_corner-left" style="background: url('{T_THEME_PATH}/images/menu/{S_MENU_COLOR}/menu_corner.gif') no-repeat;"></span>
<span class="menu_corner-right" style="background: url('{T_THEME_PATH}/images/menu/{S_MENU_COLOR}/menu_corner_right.gif') no-repeat;"></span>
<!-- IF S_DISPLAY_SEARCH and S_MENU_SEARCH -->
<div id="top-search" style="<!-- IF S_MENU_ALIGN == 'right' -->float: left;<!-- ELSE -->float: right;<!-- ENDIF -->background: transparent url('{T_THEME_PATH}/images/menu/{S_MENU_COLOR}/menu_search.gif') no-repeat scroll 0 0;">
<form action="{U_SEARCH}" method="post" id="search">
<fieldset>
<input name="keywords" id="keywords" type="text" maxlength="128" title="{L_SEARCH_KEYWORDS}" class="menu_search" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" />
{S_SEARCH_HIDDEN_FIELDS}
</fieldset>
</form>
<ul>
<!-- BEGIN menu -->
<li class="menu_button" style="float:{S_MENU_ALIGN};"><a href="{menu.BUTTON_URL}" title="{menu.BUTTON_NAME}"<!-- IF menu.BUTTON_TARGET --> rel="external"<!-- ENDIF --> style="font-weight:{S_MENU_WEIGHT};text-transform:{S_MENU_TEXT_TRANSFORM};">{menu.BUTTON_NAME}</a></li>
<!-- END menu -->
</ul>
<!-- ENDIF -->??? ???
</fieldset>
</form>
<!-- ENDIF -->كود: تحديد الكل
</fieldset>
</form>
</div><!-- /sn-nli-content -->
</div><!-- /sn-not-logged-in-hover -->
<!-- ENDIF --><!-- /s-user-not-logged-in -->??? ????? ????? ??? ????? Buttons menu
</div><!-- /sn-header-content -->
</div><!-- /sn-header -->كود: تحديد الكل
<div class="inner">
<fieldset>
</fieldset>
</form>
<ul>
<!-- BEGIN menu -->
<!-- END menu -->
</ul>
<!-- ENDIF -->قائمة بالهاكات التي عربتها
المتصفحون للمنتدى الآن: Bing [Bot], GoogleBot وزائر واحد
