[1.0.2] تصغير الصور
- islamlion_1
 - مشاركات: 590
[1.0.2] ????? ?????
???? ????? ??? ????? ???? ??? ??? ??? editor
الصفحة الرئيسية
http://www.millingtec.com
المنتديات
http://www.millingtec.com/php
الصفحة الرئيسية
المنتديات
- islamlion_1
 - مشاركات: 590
[1.0.2] ????? ?????
??? ????? ??? ????? ??????? ????? ?? 6 ????
الصفحة الرئيسية
المنتديات
الصفحة الرئيسية
المنتديات
[1.0.2] ????? ?????
[1.0.2] ????? ?????
??? editor.js ??? ????? ???? ???????? ?? ????? ???? ??? ?????? richedit/ editor.js /???????
???? ??? common.php ???? ????? ??????? ??????? ???? ????? :
??? ????? ?????? editor4.2 ??? ???? ??? IE8 ????? ?????? ?????? ????? ???????
<?php
* @package phpBB3
* @version $Id: common.php 8760 2008-08-15 19:46:51Z aptx $
* @copyright (c) 2005 phpBB Group
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
* Minimum Requirement: PHP 4.3.3
if (!defined('IN_PHPBB'))
   exit;
$starttime = explode(' ', microtime());
$starttime = $starttime[1] + $starttime[0];
// Report all errors, except notices
error_reporting(E_ALL ^ E_NOTICE);
function BBCodeToHTML($text){
   $patterns[] = "#  #si";
   $replacements[] = '  ';
   $patterns[] = "#\t#si";
   //Support Table here
   $patterns[] = "#\[table\]#si";
   $replacements[] = '<table class="tablebg" cellspacing="1" width="100%">';
   $patterns[] = "#\[\/table\]#si";
   $replacements[] = '</table>';
   $patterns[] = "#\[td\]#si";
   $replacements[] = '<td class="row2" colspan="2" align="center"><span class="gensmall">';
   $patterns[] = "#\[\/td\]#si";
   $replacements[] = '</span></td>';
   $patterns[] = "#\[tr\]#si";
   $replacements[] = '<tr>';
   $patterns[] = "#\[\/tr\]#si";
   $replacements[] = '</tr>';
   $patterns[] = "#\[(indent|blockquote)\]#si";
   $replacements[] = "<blockquote>";
   $patterns[] = "#\[\/(indent|blockquote)\]#si";
   $replacements[] = "</blockquote>";
   $patterns[] = "#\[(sub|sup|strike)(.*?)\]#si";
   $replacements[] = '<$1>';
   $patterns[] = "#\[\/(sub|sup|strike)(.*?)\]#si";
   $replacements[] = '</$1>';
   $patterns[] = "#\[size=85(.*?)\]#si";
   $replacements[] = '<span style="font-size: 8pt; line-height:125%">';
   $patterns[] = "#\[size=100(.*?)\]#si";
   $replacements[] = '<span style="font-size: 10pt; line-height:125%">';
   $patterns[] = "#\[size=120(.*?)\]#si";
   $replacements[] = '<span style="font-size: 12pt; line-height:125%">';
   $patterns[] = "#\[size=130(.*?)\]#si";
   $replacements[] = '<span style="font-size: 14pt; line-height:125%">';
   $patterns[] = "#\[size=150(.*?)\]#si";
   $replacements[] = '<span style="font-size: 16pt; line-height:125%">';
   $patterns[] = "#\[size=170(.*?)\]#si";
   $replacements[] = '<span style="font-size: 18pt; line-height:125%">';
   $patterns[] = "#\[size=200(.*?)\]#si";
   $replacements[] = '<span style="font-size: 24pt; line-height:125%">';
   $patterns[] = "#\[font=(.*?)\]#si";
   $replacements[] = '<span style="font-family:$1;">';
   $patterns[] = "#\[color=(.*?)\]#si";
   $replacements[] = '<span style="color:$1;">';
   $patterns[] = "#\[highlight=(.*?)\]#si";
   $replacements[] = '<span style="background-color:$1;">';
   $patterns[] = "#\[\/(font|highlight|color|size)(.*?)\]#si";
   $replacements[] = '</span>';
   $patterns[] = "#\[hr\]#si";
   $replacements[] = '<hr class=HR_Color>';
   $patterns[] = "#\[(left|center|right|justify)\]#si";
   $replacements[] = '<div align="$1">';
   $patterns[] = "#\[\/(left|center|right|justify)\]#si";
   $replacements[] = '</div>';
   $text = preg_replace($patterns, $replacements, $text);
   return $text;
* Remove variables created by register_globals from the global scope
* Thanks to Matt Kavanagh
function deregister_globals()
   $not_unset = array(
      'GLOBALS'   => true,
      '_GET'      => true,
      '_POST'      => true,
      '_COOKIE'   => true,
      '_REQUEST'   => true,
      '_SERVER'   => true,
      '_SESSION'   => true,
      '_ENV'      => true,
      '_FILES'   => true,
      'phpEx'      => true,
      'phpbb_root_path'   => true
   // Not only will array_merge and array_keys give a warning if
   // a parameter is not an array, array_merge will actually fail.
   // So we check if _SESSION has been initialised.
   if (!isset($_SESSION) || !is_array($_SESSION))
      $_SESSION = array();
   // Merge all into one extremely huge array; unset this later
   $input = array_merge(
      array_keys($_GET),
      array_keys($_POST),
      array_keys($_COOKIE),
      array_keys($_SERVER),
      array_keys($_SESSION),
      array_keys($_ENV),
      array_keys($_FILES)
   foreach ($input as $varname)
      if (isset($not_unset[$varname]))
         // Hacking attempt. No point in continuing unless it's a COOKIE
         if ($varname !== 'GLOBALS' || isset($_GET['GLOBALS']) || isset($_POST['GLOBALS']) || isset($_SERVER['GLOBALS']) || isset($_SESSION['GLOBALS']) || isset($_ENV['GLOBALS']) || isset($_FILES['GLOBALS']))
            exit;
            $cookie = &$_COOKIE;
            while (isset($cookie['GLOBALS']))
               foreach ($cookie['GLOBALS'] as $registered_var => $value)
                  if (!isset($not_unset[$registered_var]))
                     unset($GLOBALS[$registered_var]);
               $cookie = &$cookie['GLOBALS'];
      unset($GLOBALS[$varname]);
   unset($input);
// If we are on PHP >= 6.0.0 we do not need some code
if (version_compare(PHP_VERSION, '6.0.0-dev', '>='))
   * @ignore
   define('STRIP', false);
   @set_magic_quotes_runtime(0);
   // Be paranoid with passed vars
   if (@ini_get('register_globals') == '1' || strtolower(@ini_get('register_globals')) == 'on' || !function_exists('ini_get'))
      deregister_globals();
   define('STRIP', (get_magic_quotes_gpc()) ? true : false);
if (defined('IN_CRON'))
   $phpbb_root_path = dirname(__FILE__) . DIRECTORY_SEPARATOR;
if (!file_exists($phpbb_root_path . 'config.' . $phpEx))
   die("<p>The config.$phpEx file could not be found.</p><p><a href=\"{$phpbb_root_path}install/index.$phpEx\">Click here to install phpBB</a></p>");
require($phpbb_root_path . 'config.' . $phpEx);
if (!defined('PHPBB_INSTALLED'))
   // Redirect the user to the installer
   // We have to generate a full HTTP/1.1 header here since we can't guarantee to have any of the information
   // available as used by the redirect function
   $server_name = (!empty($_SERVER['HTTP_HOST'])) ? strtolower($_SERVER['HTTP_HOST']) : ((!empty($_SERVER['SERVER_NAME'])) ? $_SERVER['SERVER_NAME'] : getenv('SERVER_NAME'));
   $server_port = (!empty($_SERVER['SERVER_PORT'])) ? (int) $_SERVER['SERVER_PORT'] : (int) getenv('SERVER_PORT');
   $secure = (isset($_SERVER['HTTPS']) && $_SERVER['HTTPS'] == 'on') ? 1 : 0;
   $script_name = (!empty($_SERVER['PHP_SELF'])) ? $_SERVER['PHP_SELF'] : getenv('PHP_SELF');
   if (!$script_name)
      $script_name = (!empty($_SERVER['REQUEST_URI'])) ? $_SERVER['REQUEST_URI'] : getenv('REQUEST_URI');
   // Replace any number of consecutive backslashes and/or slashes with a single slash
   // (could happen on some proxy setups and/or Windows servers)
   $script_path = trim(dirname($script_name)) . '/install/index.' . $phpEx;
   $script_path = preg_replace('#[\\\\/]{2,}#', '/', $script_path);
   $url = (($secure) ? 'https://' : 'http://') . $server_name;
   if ($server_port && (($secure && $server_port <> 443) || (!$secure && $server_port <> 80)))
      // HTTP HOST can carry a port number...
      if (strpos($server_name, ':') === false)
         $url .= ':' . $server_port;
   $url .= $script_path;
   header('Location: ' . $url);
   exit;
if (defined('DEBUG_EXTRA'))
   $base_memory_usage = 0;
   if (function_exists('memory_get_usage'))
      $base_memory_usage = memory_get_usage();
// Load Extensions
if (!empty($load_extensions))
   $load_extensions = explode(',', $load_extensions);
   foreach ($load_extensions as $extension)
      @dl(trim($extension));
// Include files
require($phpbb_root_path . 'includes/acm/acm_' . $acm_type . '.' . $phpEx);
require($phpbb_root_path . 'includes/cache.' . $phpEx);
require($phpbb_root_path . 'includes/template.' . $phpEx);
require($phpbb_root_path . 'includes/session.' . $phpEx);
require($phpbb_root_path . 'includes/auth.' . $phpEx);
require($phpbb_root_path . 'includes/functions.' . $phpEx);
require($phpbb_root_path . 'includes/functions_content.' . $phpEx);
require($phpbb_root_path . 'includes/constants.' . $phpEx);
require($phpbb_root_path . 'includes/db/' . $dbms . '.' . $phpEx);
require($phpbb_root_path . 'includes/utf/utf_tools.' . $phpEx);
// Set PHP error handler to ours
set_error_handler(defined('PHPBB_MSG_HANDLER') ? PHPBB_MSG_HANDLER : 'msg_handler');
// Instantiate some basic classes
$user      = new user();
$auth      = new auth();
$template   = new template();
$cache      = new cache();
$db         = new $sql_db();
// Connect to DB
$db->sql_connect($dbhost, $dbuser, $dbpasswd, $dbname, $dbport, false, defined('PHPBB_DB_NEW_LINK') ? PHPBB_DB_NEW_LINK : false);
// We do not need this any longer, unset for safety purposes
unset($dbpasswd);
// Grab global variables, re-cache if necessary
$config = $cache->obtain_config();
// Add own hook handler
require($phpbb_root_path . 'includes/hooks/index.' . $phpEx);
$phpbb_hook = new phpbb_hook(array('exit_handler', 'phpbb_user_session_handler', 'append_sid', array('template', 'display')));
foreach ($cache->obtain_hooks() as $hook)
   @include($phpbb_root_path . 'includes/hooks/' . $hook . '.' . $phpEx);
- islamlion_1
 - مشاركات: 590
[1.0.2] ????? ?????
????? ??? ??? ????? ??? ??? common
??? ????? ???? ??? editor ??? ??? richedt
					آخر تعديل بواسطة islamlion_1 في السبت يونيو 05, 2010 11:49 pm، تم التعديل مرة واحدة.
الصفحة الرئيسية
المنتديات
الصفحة الرئيسية
المنتديات
[1.0.2] ????? ?????
????? editor ??????? ??? : http://egyptianweb.ueuo.com/viewtopic.p ... 67c6bceede
- islamlion_1
 - مشاركات: 590
[1.0.2] ????? ?????
الصفحة الرئيسية
المنتديات
الصفحة الرئيسية
المنتديات
[1.0.2] ????? ?????
					آخر تعديل بواسطة AY_MAN في الأحد يونيو 06, 2010 2:44 am، تم التعديل مرة واحدة.
						- islamlion_1
 - مشاركات: 590
[1.0.2] ????? ?????
AY_MAN كتب:??????
الصفحة الرئيسية
المنتديات
الصفحة الرئيسية
المنتديات
[1.0.2] ????? ?????
pg4soft كتب:yasorno1 كتب: ????? ????? ???? ??????? ??? ?????? ??????? ???????? ?? ?????? ??????? ??????? ???? ??????? ???? ?? ???? ?????
?? ??????? ??? ???????? 3.0.6 ? 3.0.7
???? prosilver ? subsilver2
up
[1.0.2] ????? ?????
						[1.0.2] ????? ?????
[1.0.2] ????? ?????
Open your browser and navigate to your forum. Once there put install_reimg.php in the URL and delete once process completes. Remember to refresh the prosilver template and imageset, and purge the cache.
