عاجل جدا ....... ارجو الرد
فضلاً قبل وضع أي مشكلة تأكد من استخدام البحث ومن ثم ملء استمارة الدعم إذا لم تجد حلا لمشكلتك.
???? ????? ????? ??? ????? ??? posting_bdy ??????? ?? ??????? ??????? ?????? ??? ??????? ??? ??? ????? ?? ??? ??????.
http://www.phpbbarabia.com/board/viewto ... 863#136863
??????? ???? ?????? ??? ?????? ???? ?? ??? (????-?????-????) ?????? ???? ?? ?????? center ???? ??? ????? ???? ?????? ???????.
??? ?? ???? ????? center ??? ??? ??? ?????? ???? lift ?? right .
imageTag = false;
// Shows the help messages in the helpline window
function helpline(help) {
document.post.helpbox.value = eval(help + "_help");
// Replacement for arrayname.length property
function getarraysize(thearray) {
for (i = 0; i < thearray.length; i++) {
if ((thearray == "undefined") || (thearray == "") || (thearray == null))
return i;
return thearray.length;
// Replacement for arrayname.push(value) not implemented in IE until version 5.5
// Appends element to the array
function arraypush(thearray,value) {
thearray[ getarraysize(thearray) ] = value;
// Replacement for arrayname.pop() not implemented in IE until version 5.5
// Removes and returns the last element of an array
function arraypop(thearray) {
thearraysize = getarraysize(thearray);
retval = thearray[thearraysize - 1];
delete thearray[thearraysize - 1];
return retval;
function checkForm() {
formErrors = false;
if (document.post.message.value.length < 2) {
formErrors = "{L_EMPTY_MESSAGE}";
if (formErrors) {
alert(formErrors);
return false;
} else {
bbstyle(-1);
//formObj.preview.disabled = true;
//formObj.submit.disabled = true;
return true;
function emoticon(text) {
var txtarea = document.post.message;
text = ' ' + text + ' ';
if (txtarea.createTextRange && txtarea.caretPos) {
var caretPos = txtarea.caretPos;
caretPos.text = caretPos.text.charAt(caretPos.text.length - 1) == ' ' ? caretPos.text + text + ' ' : caretPos.text + text;
txtarea.focus();
} else {
txtarea.value += text;
txtarea.focus();
function bbfontstyle(bbopen, bbclose) {
if ((clientVer >= 4) && is_ie && is_win) {
theSelection = document.selection.createRange().text;
if (!theSelection) {
txtarea.value += bbopen + bbclose;
txtarea.focus();
return;
document.selection.createRange().text = bbopen + theSelection + bbclose;
txtarea.focus();
return;
else if (txtarea.selectionEnd && (txtarea.selectionEnd - txtarea.selectionStart > 0))
mozWrap(txtarea, bbopen, bbclose);
return;
txtarea.focus();
storeCaret(txtarea);
function bbstyle(bbnumber) {
txtarea.focus();
donotinsert = false;
theSelection = false;
bblast = 0;
if (bbnumber == -1) { // Close all open tags & default button names
while (bbcode[0]) {
butnumber = arraypop(bbcode) - 1;
txtarea.value += bbtags[butnumber + 1];
buttext = eval('document.post.addbbcode' + butnumber + '.value');
eval('document.post.addbbcode' + butnumber + '.value ="' + buttext.substr(0,(buttext.length - 1)) + '"');
imageTag = false; // All tags are closed including image tags
txtarea.focus();
return;
theSelection = document.selection.createRange().text; // Get text selection
if (theSelection) {
// Add tags around selection
document.selection.createRange().text = bbtags[bbnumber] + theSelection + bbtags[bbnumber+1];
txtarea.focus();
theSelection = '';
return;
mozWrap(txtarea, bbtags[bbnumber], bbtags[bbnumber+1]);
return;
// Find last occurance of an open tag the same as the one just clicked
for (i = 0; i < bbcode.length; i++) {
if (bbcode == bbnumber+1) {
bblast = i;
donotinsert = true;
if (donotinsert) { // Close all open tags up to the one just clicked & default button names
while (bbcode[bblast]) {
imageTag = false;
txtarea.focus();
return;
} else { // Open tags
if (imageTag && (bbnumber != 14)) { // Close image tag before adding another
txtarea.value += bbtags[15];
lastValue = arraypop(bbcode) - 1; // Remove the close image tag from the list
document.post.addbbcode14.value = "Img"; // Return button back to normal state
imageTag = false;
// Open tag
txtarea.value += bbtags[bbnumber];
if ((bbnumber == 14) && (imageTag == false)) imageTag = 1; // Check to stop additional tags after an unclosed image tag
arraypush(bbcode,bbnumber+1);
eval('document.post.addbbcode'+bbnumber+'.value += "*"');
txtarea.focus();
return;
// From http://www.massless.org/mozedit/
function mozWrap(txtarea, open, close)
var selLength = txtarea.textLength;
var selStart = txtarea.selectionStart;
var selEnd = txtarea.selectionEnd;
if (selEnd == 1 || selEnd == 2)
selEnd = selLength;
var s1 = (txtarea.value).substring(0,selStart);
var s2 = (txtarea.value).substring(selStart, selEnd)
var s3 = (txtarea.value).substring(selEnd, selLength);
txtarea.value = s1 + open + s2 + close + s3;
return;
// Insert at Claret position. Code from
// http://www.faqts.com/knowledge_base/vie ... 52/fid/130
function storeCaret(textEl) {
if (textEl.createTextRange) textEl.caretPos = document.selection.createRange().duplicate();
</script>
<!-- BEGIN privmsg_extensions -->
<table border="0" cellspacing="0" cellpadding="0" align="center" width="100%">
<td valign="top" align="center" width="100%">
<table height="40" cellspacing="2" cellpadding="2" border="0">
<tr valign="middle">
<td>{INBOX_IMG}</td>
<td><span class="cattitle">{INBOX_LINK} </span></td>
<td>{SENTBOX_IMG}</td>
<td><span class="cattitle">{SENTBOX_LINK} </span></td>
<td>{OUTBOX_IMG}</td>
<td><span class="cattitle">{OUTBOX_LINK} </span></td>
<td>{SAVEBOX_IMG}</td>
<td><span class="cattitle">{SAVEBOX_LINK} </span></td>
<br clear="all" />
<!-- END privmsg_extensions -->
<form action="{S_POST_ACTION}" method="post" name="post" onsubmit="return checkForm(this)" {S_FORM_ENCTYPE}>
{POST_PREVIEW_BOX}
{ERROR_BOX}
<table width="100%" cellspacing="2" cellpadding="2" border="0" align="center">
<td align="left"><span class="nav"><a href="{U_INDEX}" class="nav">{L_INDEX}</a>
<!-- BEGIN switch_not_privmsg -->
-> <a href="{U_VIEW_FORUM}" class="nav">{FORUM_NAME}</a></span></td>
<!-- END switch_not_privmsg -->
<table border="0" cellpadding="3" cellspacing="1" width="100%" class="forumline">
<th class="thHead" colspan="2" height="25"><b>{L_POST_A}</b></th>
<!-- BEGIN switch_username_select -->
<td class="row1"><span class="gen"><b>{L_USERNAME}</b></span></td>
<td class="row2"><span class="genmed"><input type="text" class="post" tabindex="1" name="username" size="25" maxlength="25" value="{USERNAME}" /></span></td>
<!-- END switch_username_select -->
<!-- BEGIN switch_privmsg -->
<td class="row2"><span class="genmed"><input type="text" class="post" name="username" maxlength="25" size="25" tabindex="1" value="{USERNAME}" /> <input type="submit" name="usersubmit" value="{L_FIND_USERNAME}" class="liteoption" onClick="window.open('{U_SEARCH_USER}', '_phpbbsearch', 'HEIGHT=250,resizable=yes,WIDTH=400');return false;" /></span></td>
<!-- END switch_privmsg -->
<td class="row1" width="22%"><span class="gen"><b>{L_SUBJECT}</b></span></td>
<td class="row2" width="78%"> <span class="gen">
<input type="text" name="subject" size="45" maxlength="60" style="width:500px" tabindex="2" class="post" value="{SUBJECT}" />
</span> </td>
<td class="row1" valign="top">
<table width="100%" border="0" cellspacing="0" cellpadding="1">
<td><span class="gen"><b>{L_MESSAGE_BODY}</b></span> </td>
<td valign="middle" align="center"> <br />
<table width="100" border="0" cellspacing="0" cellpadding="5">
<tr align="center">
<td colspan="{S_SMILIES_COLSPAN}" class="gensmall"><b>{L_EMOTICONS}</b></td>
<!-- BEGIN smilies_row -->
<tr align="center" valign="middle">
<!-- BEGIN smilies_col -->
<td><a href="javascript:emoticon('{smilies_row.smilies_col.SMILEY_CODE}')"><img src="{smilies_row.smilies_col.SMILEY_IMG}" border="0" alt="{smilies_row.smilies_col.SMILEY_DESC}" title="{smilies_row.smilies_col.SMILEY_DESC}" /></a></td>
<!-- END smilies_col -->
<!-- END smilies_row -->
<!-- BEGIN switch_smilies_extra -->
<tr align="center">
<td colspan="{S_SMILIES_COLSPAN}"><span class="nav"><a href="{U_MORE_SMILIES}" onclick="window.open('{U_MORE_SMILIES}', '_phpbbsmilies', 'HEIGHT=300,resizable=yes,scrollbars=yes,WIDTH=250');return false;" target="_phpbbsmilies" class="nav">{L_MORE_SMILIES}</a></span></td>
<!-- END switch_smilies_extra -->
<td class="row2" valign="top"><span class="gen"> <span class="genmed"> </span>
<table width="600" border="0" cellspacing="0" cellpadding="2">
<td><span class="genmed">
<input type="button" class="button" accesskey="b" name="addbbcode0" value=" B " style="font-weight:bold; width: 30px" onClick="bbstyle(0)" onMouseOver="helpline('b')" />
</span></td>
<input type="button" class="button" accesskey="i" name="addbbcode2" value=" i " style="font-style:italic; width: 30px" onClick="bbstyle(2)" onMouseOver="helpline('i')" />
</span></td>
<input type="button" class="button" accesskey="u" name="addbbcode4" value=" u " style="text-decoration: underline; width: 30px" onClick="bbstyle(4)" onMouseOver="helpline('u')" />
</span></td>
<input type="button" class="button" accesskey="q" name="addbbcode6" value="Quote" style="width: 50px" onClick="bbstyle(6)" onMouseOver="helpline('q')" />
</span></td>
<input type="button" class="button" accesskey="c" name="addbbcode8" value="Code" style="width: 40px" onClick="bbstyle(8)" onMouseOver="helpline('c')" />
</span></td>
<input type="button" class="button" accesskey="l" name="addbbcode10" value="List" style="width: 40px" onClick="bbstyle(10)" onMouseOver="helpline('l')" />
</span></td>
<input type="button" class="button" accesskey="o" name="addbbcode12" value="List=" style="width: 40px" onClick="bbstyle(12)" onMouseOver="helpline('o')" />
</span></td>
<input type="button" class="button" accesskey="p" name="addbbcode14" value="Img" style="width: 40px" onClick="bbstyle(14)" onMouseOver="helpline('p')" />
</span></td>
<input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="text-decoration: underline; width: 40px" onClick="bbstyle(16)" onMouseOver="helpline('w')" />
</span></td>
<input type="button" class="button" accesskey="t" name="addbbcode18" value="TeX" style="width: 40px" onClick="bbstyle(18)" onMouseOver="helpline('t')" />
</span></td>
<td colspan="9">
<table width="100%" border="0" cellspacing="0" cellpadding="0">
<td><span class="genmed"> {L_FONT_COLOR}:
<select name="addbbcode20" onChange="bbfontstyle('[color=' + this.form.addbbcode20.options[this.form.addbbcode20.selectedIndex].value + ']', '[/color]');this.selectedIndex=0;" onMouseOver="helpline('s')">
<option style="color:black; background-color: {T_TD_COLOR1}" value="{T_FONTCOLOR1}" class="genmed">{L_COLOR_DEFAULT}</option>
<option style="color:darkred; background-color: {T_TD_COLOR1}" value="darkred" class="genmed">{L_COLOR_DARK_RED}</option>
<option style="color:red; background-color: {T_TD_COLOR1}" value="red" class="genmed">{L_COLOR_RED}</option>
<option style="color:orange; background-color: {T_TD_COLOR1}" value="orange" class="genmed">{L_COLOR_ORANGE}</option>
<option style="color:brown; background-color: {T_TD_COLOR1}" value="brown" class="genmed">{L_COLOR_BROWN}</option>
<option style="color:yellow; background-color: {T_TD_COLOR1}" value="yellow" class="genmed">{L_COLOR_YELLOW}</option>
<option style="color:green; background-color: {T_TD_COLOR1}" value="green" class="genmed">{L_COLOR_GREEN}</option>
<option style="color:olive; background-color: {T_TD_COLOR1}" value="olive" class="genmed">{L_COLOR_OLIVE}</option>
<option style="color:cyan; background-color: {T_TD_COLOR1}" value="cyan" class="genmed">{L_COLOR_CYAN}</option>
<option style="color:blue; background-color: {T_TD_COLOR1}" value="blue" class="genmed">{L_COLOR_BLUE}</option>
<option style="color:darkblue; background-color: {T_TD_COLOR1}" value="darkblue" class="genmed">{L_COLOR_DARK_BLUE}</option>
<option style="color:indigo; background-color: {T_TD_COLOR1}" value="indigo" class="genmed">{L_COLOR_INDIGO}</option>
<option style="color:violet; background-color: {T_TD_COLOR1}" value="violet" class="genmed">{L_COLOR_VIOLET}</option>
<option style="color:white; background-color: {T_TD_COLOR1}" value="white" class="genmed">{L_COLOR_WHITE}</option>
<option style="color:black; background-color: {T_TD_COLOR1}" value="black" class="genmed">{L_COLOR_BLACK}</option>
</select> {L_FONT_SIZE}:<select name="addbbcode22" onChange="bbfontstyle('[size=' + this.form.addbbcode22.options[this.form.addbbcode22.selectedIndex].value + ']', '[/size]');this.selectedIndex=0;" onMouseOver="helpline('f')">
<option value="0" class="genmed">{L_FONT_SIZE}</option>
<option value="7" class="genmed">{L_FONT_TINY}</option>
<option value="9" class="genmed">{L_FONT_SMALL}</option>
<option value="12" selected class="genmed">{L_FONT_NORMAL}</option>
<option value="18" class="genmed">{L_FONT_LARGE}</option>
<option value="24" class="genmed">{L_FONT_HUGE}</option>
</select> {L_FONT_ALIGN}:<select name="addbbcode24" onChange="bbfontstyle('[align=' + this.form.addbbcode24.options[this.form.addbbcode24.selectedIndex].value + ']', '[/align]')" onMouseOver="helpline('x')">
<option value="left" class="genmed">{L_ALIGN_LEFT}</option>
<option value="center" class="genmed">{L_ALIGN_CENTER}</option>
<option value="right" selected class="genmed">{L_ALIGN_RIGHT}</option>
</select>
</span></td>
<td nowrap="nowrap" align="right"><span class="gensmall"><a href="javascript:bbstyle(-1)" class="genmed" onMouseOver="helpline('a')">{L_BBCODE_CLOSE_TAGS}</a></span></td>
<td colspan="9"> <span class="gensmall">
<input type="text" name="helpbox" size="45" maxlength="100" style="width:450px; font-size:10px" class="helpline" value="{L_STYLES_TIP}" />
</span></td>
<td colspan="10"><span class="gen">
<textarea name="message" rows="15" cols="35" wrap="virtual" style="width:500px" tabindex="3" class="post" onselect="storeCaret(this);" onclick="storeCaret(this);" onkeyup="storeCaret(this);">{MESSAGE}</textarea>
</span></td>
</span></td>
<td class="row1" valign="top"><span class="gen"><b>{L_OPTIONS}</b></span><br /><span class="gensmall">{HTML_STATUS}<br />{BBCODE_STATUS}<br />{SMILIES_STATUS}</span></td>
<td class="row2"><span class="gen"> </span>
<table cellspacing="0" cellpadding="1" border="0">
<!-- BEGIN switch_html_checkbox -->
<td>
<input type="checkbox" name="disable_html" {S_HTML_CHECKED} />
<td><span class="gen">{L_DISABLE_HTML}</span></td>
<!-- END switch_html_checkbox -->
<!-- BEGIN switch_bbcode_checkbox -->
<td>
<input type="checkbox" name="disable_bbcode" {S_BBCODE_CHECKED} />
<td><span class="gen">{L_DISABLE_BBCODE}</span></td>
<!-- END switch_bbcode_checkbox -->
<!-- BEGIN switch_smilies_checkbox -->
<td>
<input type="checkbox" name="disable_smilies" {S_SMILIES_CHECKED} />
<td><span class="gen">{L_DISABLE_SMILIES}</span></td>
<!-- END switch_smilies_checkbox -->
<!-- BEGIN switch_signature_checkbox -->
<td>
<input type="checkbox" name="attach_sig" {S_SIGNATURE_CHECKED} />
<td><span class="gen">{L_ATTACH_SIGNATURE}</span></td>
<!-- END switch_signature_checkbox -->
<!-- BEGIN switch_notify_checkbox -->
<td>
<input type="checkbox" name="notify" {S_NOTIFY_CHECKED} />
<td><span class="gen">{L_NOTIFY_ON_REPLY}</span></td>
<!-- END switch_notify_checkbox -->
<!-- BEGIN switch_delete_checkbox -->
<td>
<input type="checkbox" name="delete" />
<td><span class="gen">{L_DELETE_POST}</span></td>
<!-- END switch_delete_checkbox -->
<!-- BEGIN switch_type_toggle -->
<td></td>
<td><span class="gen">{S_TYPE_TOGGLE}</span></td>
<!-- END switch_type_toggle -->
{ATTACHBOX}
{POLLBOX}
<td class="catBottom" colspan="2" align="center" height="28"> {S_HIDDEN_FORM_FIELDS}<input type="submit" tabindex="5" name="preview" class="mainoption" value="{L_PREVIEW}" /> <input type="submit" accesskey="s" tabindex="6" name="post" class="mainoption" value="{L_SUBMIT}" /></td>
<table width="100%" cellspacing="2" border="0" align="center" cellpadding="2">
<td align="right" valign="top"><span class="gensmall">{S_TIMEZONE}</span></td>
</form>
<table width="100%" cellspacing="2" border="0" align="center">
<td valign="top" align="right">{JUMPBOX}</td>
{TOPIC_REVIEW_BOX}
[/code]
<script language="JavaScript" type="text/javascript">
// bbCode control by
// subBlue design
// www.subBlue.com
// Startup variables
var imageTag = false;
var theSelection = false;
// Check for Browser & Platform for PC & IE specific bits
// More details from: http://www.mozilla.org/docs/web-developer/sniffer/browser_type.html
var clientPC = navigator.userAgent.toLowerCase(); // Get client info
var clientVer = parseInt(navigator.appVersion); // Get browser version
var is_ie = ((clientPC.indexOf("msie") != -1) && (clientPC.indexOf("opera") == -1));
var is_nav = ((clientPC.indexOf('mozilla')!=-1) && (clientPC.indexOf('spoofer')==-1)
&& (clientPC.indexOf('compatible') == -1) && (clientPC.indexOf('opera')==-1)
&& (clientPC.indexOf('webtv')==-1) && (clientPC.indexOf('hotjava')==-1));
var is_moz = 0;
var is_win = ((clientPC.indexOf("win")!=-1) || (clientPC.indexOf("16bit") != -1));
var is_mac = (clientPC.indexOf("mac")!=-1);
// Helpline messages
b_help = "{L_BBCODE_B_HELP}";
i_help = "{L_BBCODE_I_HELP}";
u_help = "{L_BBCODE_U_HELP}";
q_help = "{L_BBCODE_Q_HELP}";
c_help = "{L_BBCODE_C_HELP}";
l_help = "{L_BBCODE_L_HELP}";
o_help = "{L_BBCODE_O_HELP}";
p_help = "{L_BBCODE_P_HELP}";
w_help = "{L_BBCODE_W_HELP}";
a_help = "{L_BBCODE_A_HELP}";
s_help = "{L_BBCODE_S_HELP}";
f_help = "{L_BBCODE_F_HELP}";
T_help = "{L_BBCODE_T_HELP}";
x_help = "{L_BBCODE_X_HELP}";
// Define the bbCode tags
bbcode = new Array();
bbtags = new Array('[b]','[/b]','[i]','[/i]','[u]','[/u]','[quote]','[/quote]','[code]','- ','
imageTag = false;
return i;
return retval;
formErrors = false;
if (formErrors) {
alert(formErrors);
return false;
} else {
bbstyle(-1);
return true;
txtarea.focus();
} else {
txtarea.focus();
txtarea.focus();
return;
txtarea.focus();
return;
return;
txtarea.focus();
txtarea.focus();
bblast = 0;
while (bbcode[0]) {
txtarea.focus();
return;
if (theSelection) {
txtarea.focus();
theSelection = '';
return;
return;
bblast = i;
donotinsert = true;
imageTag = false;
txtarea.focus();
return;
imageTag = false;
// Open tag
txtarea.focus();
return;
selEnd = selLength;
return;
</script>
<br clear="all" />
{POST_PREVIEW_BOX}
{ERROR_BOX}
</span> </td>
<tr align="center">
<tr align="center">
</span></td>
</span></td>
</span></td>
</span></td>
</span></td>
</span></td>
</span></td>
</span></td>
</span></td>
</span></td>
<td colspan="9">
</select>
</span></td>
</span></td>
</span></td>
</span></td>
<td>
<td>
<td>
<td>
<td>
<td>
<td></td>
{ATTACHBOX}
{POLLBOX}
</form>
{TOPIC_REVIEW_BOX}
[/code]
