[RC1] هاك آخر المواضيع المطور Advanced Last Topics
[RC1] ??? ??? ???????? ?????? Advanced Last Topics
???? ????? : Saanina
??????? : 1.0
1-?????? ?????? ????? ???? ?????? ???????? ..
2-?????? ?????? ????? ????? ??????.
3- ?????? ?????? ???? ????????
4- ?????? ?????? ???? ??? ?????? ??????? .
5- ?????? ?????? ???? ?? ??? ???? ?? .
?????? ??????? : 1.0beta2
?????? ??????? :1.0beta3
-??? ??????? subsilver2 ????????..
??????? :1.0beta4
??????? :1.0beta5
??????? :1.0rc1
1- ??? ?????????
2- ?????? ?????? ????????
3- ??? ??? ???? ???????.
- ALT_1RC1.zip
- (56.4 KiB) حُمِّل 3709 مرات
آخر تعديل بواسطة saanina في الخميس أغسطس 30, 2007 5:31 am، تم التعديل 14 مرة في المجمل.
منتديات مهند
http://mohand.2araby.com/
- Y4$$3R N3T
- مشاركات: 2
- اشترك في: الثلاثاء يوليو 17, 2007 10:24 am
http://www.fjrona.com
DIY Instructions
These are manual instructions that cannot be performed automatically. You should follow these instructions carefully.
Code: Select All
If you want show this hack in header .. change last two steps...
-> header : index.php -> functions.php : find and add before [// application/xhtml+xml not used because of IE]
-> header : index_body.html-> overall_header.html : put in end of file
Now copy new files to there new location and refresh your style ..
thank u :)
Saanina???? ????? ??? ?? ??? ??? ??? ????
أول منتدى عربي متكامل من برمجة سورية
http://www.jamaa.co.nr
index.php
functions.php
index_body.html
overall_header.html
http://www.eng-club.com/forum/
???? ???? ?? saanina
- Y4$$3R N3T
- مشاركات: 2
?? ????? ????? ?????? ????2
?? ?????? ?????? ??????? ??? ??? ???? UPGRADE
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND topic_approved = 1 ORDER BY topic_id DESC LIMIT 0,0' at line 4 [1064]
SQL
SELECT topic_id,forum_id ,topic_title,topic_first_post_id,topic_first_poster_name,topic_first_poster_colour,topic_replies, topic_last_poster_id ,topic_last_poster_name,topic_last_poster_colour FROM phpbb_topics WHERE forum_id NOT IN () AND topic_approved = 1 ORDER BY topic_id DESC LIMIT 0,0
BACKTRACE
FILE: includes/db/mysql.php
LINE: 133
CALL: dbal_mysql->sql_error()
FILE: includes/functions.php
LINE: 4633
CALL: dbal_mysql->sql_query()
LINE: 4311
CALL: get_last_topics()
FILE: index.php
LINE: 150
CALL: page_header()
SQL
BACKTRACE
LINE: 133
LINE: 4633
LINE: 4311
FILE: index.php
LINE: 150
CALL: page_header()
المتصفحون للمنتدى الآن: DotNetDotCom.org Bot فقط
