ممكن مساعدة
??? ???? ??? ????? prosilver ??? phpBB2
???? ???? ????? ??? ???? ??? ???? ??? ??????? ?????? subsilver
http://www.mshtana.com/bb
(أبو الحب)
the shadow
- مشاركات: 763
- اشترك في: الاثنين يونيو 20, 2005 8:30 pm
- مكان: keyboard
??? ?? ??? phpbbx,
???? ????? ??? ?? Subsilver ???? ??? Prosilver
?? ?????subsilver.cfg ??? prosilver.cfg
?subsilver.css ??? prosilver.css
?? ?? ?????? ?????? prosilver ????? ???????? ??????
http://chita.us/prosilver/files/prosilv ... leonly.zip
??? ?? ??? phpbbx,
TheIlluminative
- رئيس طاقم الاستايلات
- مشاركات: 2158
- مكان: Nowhere
??? Abo Habib, ??? ?? ?????? ????? ??????? ????? ??? subSilver:
????? ?? ???? ???? ????? subSilver ??? ???? templates ?? ??????? ????.
?????? ?? ???? ??? ???? ?? ???? ??????? ???????? ??? ???? templates? ? ?? ???? ????? ?????? ???:
? ?? ?????? ??? ????? reset_template.php
?????? ?? ???? ????? ?? ????? ??????? http://www.yoursite.com/phpBB2/reset_template.php
1- ??? ????? ???? ??? ??? ???? ??? ????? ?????? MySQL ???.
2- ??? ????? ???? ?????? ??????? ????????? ??????? ???? ?? ? ??? ???????.
3- ?? ???? ????? ??? ????????? ?? ????? ?? ??????.
4- ??? ????? ??? ?????? ?? ?????? ???
? ???? ??? ??????? ??? ??????? ?????? 2.0.x ??? ??????? ?????..
<?php
define('IN_PHPBB', true);
include('./config.php');
include('./includes/constants.php');
// connect to the database server
$db = mysql_connect($dbhost,$dbuser,$dbpasswd);
if (!$db) die('Unable to connect to the database');
// select the PHPBB database
mysql_select_db($dbname, $db);
// Run the queries
$sql = array();
$sql[] = "DROP TABLE " . THEMES_TABLE;
$sql[] = "DROP TABLE " . THEMES_NAME_TABLE;
$sql[] = "CREATE TABLE " . THEMES_TABLE . " (
`themes_id` mediumint(8) unsigned NOT NULL auto_increment,
`template_name` varchar(30) NOT NULL default '',
`style_name` varchar(30) NOT NULL default '',
`head_stylesheet` varchar(100) default NULL,
`body_background` varchar(100) default NULL,
`body_bgcolor` varchar(6) default NULL,
`body_text` varchar(6) default NULL,
`body_link` varchar(6) default NULL,
`body_vlink` varchar(6) default NULL,
`body_alink` varchar(6) default NULL,
`body_hlink` varchar(6) default NULL,
`tr_color1` varchar(6) default NULL,
`tr_color2` varchar(6) default NULL,
`tr_color3` varchar(6) default NULL,
`tr_class1` varchar(25) default NULL,
`tr_class2` varchar(25) default NULL,
`tr_class3` varchar(25) default NULL,
`th_color1` varchar(6) default NULL,
`th_color2` varchar(6) default NULL,
`th_color3` varchar(6) default NULL,
`th_class1` varchar(25) default NULL,
`th_class2` varchar(25) default NULL,
`th_class3` varchar(25) default NULL,
`td_color1` varchar(6) default NULL,
`td_color2` varchar(6) default NULL,
`td_color3` varchar(6) default NULL,
`td_class1` varchar(25) default NULL,
`td_class2` varchar(25) default NULL,
`td_class3` varchar(25) default NULL,
`fontface1` varchar(50) default NULL,
`fontface2` varchar(50) default NULL,
`fontface3` varchar(50) default NULL,
`fontsize1` tinyint(4) default NULL,
`fontsize2` tinyint(4) default NULL,
`fontsize3` tinyint(4) default NULL,
`fontcolor1` varchar(6) default NULL,
`fontcolor2` varchar(6) default NULL,
`fontcolor3` varchar(6) default NULL,
`span_class1` varchar(25) default NULL,
`span_class2` varchar(25) default NULL,
`span_class3` varchar(25) default NULL,
`img_size_poll` smallint(5) unsigned default NULL,
`img_size_privmsg` smallint(5) unsigned default NULL,
PRIMARY KEY (`themes_id`)
) TYPE=MyISAM AUTO_INCREMENT=2";
$sql[] = "CREATE TABLE " . THEMES_NAME_TABLE . " (
`themes_id` smallint(5) unsigned NOT NULL default '0',
`tr_color1_name` char(50) default NULL,
`tr_color2_name` char(50) default NULL,
`tr_color3_name` char(50) default NULL,
`tr_class1_name` char(50) default NULL,
`tr_class2_name` char(50) default NULL,
`tr_class3_name` char(50) default NULL,
`th_color1_name` char(50) default NULL,
`th_color2_name` char(50) default NULL,
`th_color3_name` char(50) default NULL,
`th_class1_name` char(50) default NULL,
`th_class2_name` char(50) default NULL,
`th_class3_name` char(50) default NULL,
`td_color1_name` char(50) default NULL,
`td_color2_name` char(50) default NULL,
`td_color3_name` char(50) default NULL,
`td_class1_name` char(50) default NULL,
`td_class2_name` char(50) default NULL,
`td_class3_name` char(50) default NULL,
`fontface1_name` char(50) default NULL,
`fontface2_name` char(50) default NULL,
`fontface3_name` char(50) default NULL,
`fontsize1_name` char(50) default NULL,
`fontsize2_name` char(50) default NULL,
`fontsize3_name` char(50) default NULL,
`fontcolor1_name` char(50) default NULL,
`fontcolor2_name` char(50) default NULL,
`fontcolor3_name` char(50) default NULL,
`span_class1_name` char(50) default NULL,
`span_class2_name` char(50) default NULL,
`span_class3_name` char(50) default NULL,
) TYPE=MyISAM";
$sql[] = "INSERT INTO " . THEMES_TABLE . " VALUES (1, 'subSilver', 'subSilver', 'subSilver.css', '', 'E5E5E5', '000000', '006699', '5493B4', '', 'DD6900', 'EFEFEF', 'DEE3E7', 'D1D7DC', '', '', '', '98AAB1', '006699', 'FFFFFF', 'cellpic1.gif', 'cellpic3.gif', 'cellpic2.jpg', 'FAFAFA', 'FFFFFF', '', 'row1', 'row2', '', 'Verdana, Arial, Helvetica, sans-serif', 'Trebuchet MS', 'Courier, ''Courier New'', sans-serif', 10, 11, 12, '444444', '006600', 'FFA34F', '', '', '', NULL, NULL)";
$sql[] = "INSERT INTO " . THEMES_NAME_TABLE . " VALUES (1, 'The lightest row colour', 'The medium row color', 'The darkest row colour', '', '', '', 'Border round the whole page', 'Outer table border', 'Inner table border', 'Silver gradient picture', 'Blue gradient picture', 'Fade-out gradient on index', 'Background for quote boxes', 'All white areas', '', 'Background for topic posts', '2nd background for topic posts', '', 'Main fonts', 'Additional topic title font', 'Form fonts', 'Smallest font size', 'Medium font size', 'Normal font size (post body etc)', 'Quote & copyright text', 'Code text colour', 'Main table header text colour', '', '', '');";
$sql[] = "UPDATE " . CONFIG_TABLE . " SET config_value = 1 WHERE config_name = 'default_style' LIMIT 1";
$sql[] = "UPDATE " . CONFIG_TABLE . " SET config_value = '1' WHERE config_name = 'override_user_style' LIMIT 1";
for( $i = 0; $i < count($sql); $i++ )
$echo .= '<b>Query ' . ($i+1) . ': </b><span style="font-size: 75%;">' . $sql[$i] . '</span><br /><b>Status: </b>' . (!($result = mysql_query($sql[$i])) ? '<font color="red">Error (' . mysql_error() . ')</font><hr />' : '<font color="green">Ran successfully</font><hr />');
die( ((strpos($echo, 'color="red">Error') !== FALSE) ? '<font color="red"><b>Some queries failed</b></font><br /><br />If the problem persists, please start a topic in the support forum with a link to this article and the exact error displayed.</b>' : '<font color="green"><b>All queries have been run successfully.</b></font><br /><br />') . ' Be sure to delete this file! A detailed report follows:<br /><br /><table border="1"><tr><td>' . $echo . '</td></tr></table>');
