محتاج هاك اخفاء المواضيع
???? ?????? :- http://www.kartowm.net
?????? ???? ??????? :- 2.0.22
up up up up up up up
???? 3 ?????? ??? ??? ?? ????
- مهند قمرة
- مشاركات: 4222
- مكان: مـصـر [ولي الفخر]
ليس لديك الصلاحية لمشاهدة المرفقات
سأعود قريبا لعالمي في ارابيا
??? ????? ????? ???? ?? ?????? phpbb3
???? ????? ????? phpbb2
up up up up up up
??? ????? ?? ???? ?? ?? phpbb ???????
## MOD HIDE | Made By / Auteur: Philiweb < http://www.philiweb.fr.st/ >
## Description : MOD "HIDE" (aka lockdown) - this mod allow users to hide
## a message via some "bbcodes", ex : [hide] message [/hide]. To see the
## hidden message, you must be a member and you must post a reply to
## the message...
## VERSION DE PHPBB : PHPBB 2.0 RC3 - RC4 - 2.0.x (gold) - 2.0.4 |02/2003|
## You can find the last versions and informations here on the official
## website (in English and French) :
## http://membres.lycos.fr/philiweb/accueil.php?num=15
## Info : There is also some pre-modified files if you have difficulties !
## And you can find some modifications to "hide" mod here :
## http://membres.lycos.fr/philiweb/accueil.php?num=23
## new : version 4 => administrators and moderators can see "hidden
## messages" immediatly...)
## Demo : http://membres.lycos.fr/philiweb/forums/viewtopic.php?t=167
## This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
There is 7 files to modify :
1 - posting.php
2 - viewtopic.php
3 - search.php
4 - topic_review.php // in the "/includes" directory
5 - bbcode.php // in the "/includes" directory
6 - bbcode.tpl // in the Templates/{Used template}/ directory
7 - posting_body.tpl // in the Templates/{Used template}/ directory
This mod is easy to install. (20 mn)
1 - In posting.php
Find
if( $attach_sig && $user_sig != '' && $userdata['user_sig_bbcode_uid'] )
$user_sig = bbencode_second_pass($user_sig, $userdata['user_sig_bbcode_uid']);
if( $bbcode_on )
$preview_message = bbencode_second_pass($preview_message, $bbcode_uid);
Replace by
$valid = FALSE;
if( $userdata['session_logged_in'] ) {
$sql = "SELECT p.poster_id, p.topic_id
FROM " . POSTS_TABLE . " p
WHERE p.topic_id = $topic_id
AND p.poster_id = " . $userdata['user_id'];
$resultat = $db->sql_query($sql);
$valid = $db->sql_numrows($resultat) ? TRUE : FALSE;}
$user_sig = bbencode_third_pass($user_sig, $userdata['user_sig_bbcode_uid'], $valid);
if( $bbcode_on )
$preview_message = bbencode_third_pass($preview_message, $bbcode_uid, $valid);
Find
if ( !preg_match('/^Re:/', $subject) && strlen($subject) > 0 )
$subject = 'Re: ' . $subject;
Add Below
if( !$userdata['session_logged_in'] ) {$message = hide_in_quote($message);}
else { $sql = "SELECT p.poster_id, p.topic_id
if(!$db->sql_numrows($resultat)) {$message = hide_in_quote($message);}
2 - In viewtopic.php
Find
// Generate a 'Show posts in previous x days' select box. If the postdays var is POSTed
// then get it's value, find the number of topics with dates newer than it (to properly
// handle pagination) and alter the main query
Add below
$valid = FALSE;
Find
if ( $user_sig != '' && $user_sig_bbcode_uid != '' )
$user_sig = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($user_sig, $user_sig_bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $user_sig);
if ( $bbcode_uid != '' )
$message = ( $board_config['allow_bbcode'] ) ? bbencode_second_pass($message, $bbcode_uid) : preg_replace('/\:[0-9a-z\:]+\]/si', ']', $message);
Replace by
$user_sig = bbencode_third_pass($user_sig, $user_sig_bbcode_uid, $valid);
$message = bbencode_third_pass($message, $bbcode_uid, $valid);
3 - In search.php
Find
// If the board has HTML off but the post has HTML
// on then we process it, else leave it alone
if ( $return_chars != -1 )
And replace it by
if( $return_chars == -1 )
Find
Replace by
$message = bbencode_third_pass($message, $bbcode_uid, FALSE);
4 - In topic_review.php // in the "/includes" directory
Find
// Okay, let's do the loop, yeah come on baby let's do the loop
// and it goes like this ...
if ( $row = $db->sql_fetchrow($result) )
Add below
$valid = FALSE;
Find
if ( $bbcode_uid != "" )
Replace by
5 - In bbcode.php // in the "/includes" directory
Find
$bbcode_tpl['email'] = str_replace('{EMAIL}', '\\1', $bbcode_tpl['email']);
Add Below
$bbcode_tpl['show'] = str_replace('{HTEXTE}', '\\1', $bbcode_tpl['show']);
*Before* this text
* Does second-pass bbencoding. This should be used before displaying the message in
* a thread. Assumes the message is already first-pass encoded, and we are given the
* correct UID as used in first-pass encoding.
Add this functions
function hide_in_quote($text)
$text = preg_replace("#\[hide\](.*?)\[\/hide\]#si","--- phpBB : The Protected Message is not copied in this quote ---", $text);
return $text;
function bbencode_third_pass($text, $uid, $deprotect)
global $bbcode_tpl;
// pad it with a space so we can distinguish between FALSE and matching the 1st char (index 0).
// This is important; bbencode_quote(), bbencode_list(), and bbencode_code() all depend on it.
$text = " " . $text;
// First: If there isn't a "[" and a "]" in the message, don't bother.
if (! (strpos($text, "[") && strpos($text, "]")) )
// Remove padding, return.
$text = substr($text, 1);
return $text;
// Patterns and replacements for URL and email tags..
$patterns = array();
$replacements = array();
if ( $deprotect ) {
$patterns[0] = "#\[hide:$uid\](.*?)\[/hide:$uid\]#si";
$replacements[0] = $bbcode_tpl['show'];
$replacements[0] = $bbcode_tpl['hide'];
$text = preg_replace($patterns, $replacements, $text);
// Remove our padding from the string..
return $text;
Find in function "bbencode_first_pass"
// [img]image_url_here[/img] code..
$text = preg_replace("#\[img\](([a-z]+?)://([^ \"\n\r]+?))\[/img\]#si", "[img:$uid]\\1[/img:$uid]", $text);
Add Below
//[hide]message[/hide]
$text = preg_replace("#\[hide\](.*?)\[\/hide\]#si","[hide:$uid]\\1[/hide:$uid]", $text);
6 - In bbcode.tpl // in the Templates/{Used template}/ directory
At the top, add
<!-- BEGIN show -->
</span>
<table border="0" align="center" width="90%" cellpadding="3" cellspacing="1">
<td><span class="genmed"><b>Protected Message:</b></span></td>
<td class="quote">
{HTEXTE}
<span class="postbody">
<!-- END show -->
<!-- BEGIN hide -->
</span>
<td class="quote">
<center>--- If you are a *registered user* : you need to post in this topic to see the message ---</center>
<!-- END hide -->
7 - In posting_body.tpl // in the Templates/{Used template}/ directory
This part add a button in the dialog box (newtopic,...).
In the list of "// Helpline messages", add :
h_help = "Hide: [hide]message[/hide] (alt+h)";
Find this line :
bbtags = new Array('[b]','[/b]'...
And add at the end :
'[hide]' and '[/hide]'
You will obtain something like this :
bbtags = new Array('[b]','[/b]','[i]','[/i]','[u]','[/u]','[quote]','[/quote]','[code]','- ','
Find
<input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="text-decoration: underline; width: 40px" onClick="bbstyle(16)" onMouseOver="helpline('w')" />
</span></td>
Add Below : (Don't forget to adapt the "addbbcode" numbers if neccesary ! (exemple: addbbcode18 -> addbbcode20, 20 -> 22, etc)
<input type="button" class="button" accesskey="h" name="addbbcode18" value="Hide" style="width: 40px" onClick="bbstyle(18)" onMouseOver="helpline('h')" />
</span></td>
Next, you need to modify all the "addbbcodexx" in the rest of the file. (exemple : addbbcode20 -> addbbcode22)
That's all !
Philippe
IF YOU HAVE A PROBLEM ("undefined" instead of [hide]...) - Go on my website or contact me :
http://membres.lycos.fr/philiweb/downlo ... =7&lang=en
Official page => http://membres.lycos.fr/philiweb/accueil.php?num=15 [/code]
