تمت الترقية بنجاج الحمد لله إلى 3.03 (الطريقة المتبعة)
??? ??????? ????? ????? ??? ??? 3.03 (??????? ???????)
??? ????? ???? ??????? ?? 3.02 ??? 3.03
-??? ??????? ????? ???? ??????? ???? ??????? ??????? ?? subsilver2 (????? ????? ?????
-??? ?????? ??? ???? ??????? ??? extrapc ? subsilver2 ???? ???? ???? ????? subsilver2 ?????? ????? ??? ?? ?????? ?????
-???? ???? ??????? install ??? ???? ??????? ??? ???? ???? ?????? http://www.xxx.com/forum/install
-?????? ???? ?? ????? ??????? ?? ????? ??????? ??? ????? ??????? ????? ?????? ???????? ???? ???? ??? ??? ????? subsilver 2 ???? ??????? ???? ?????? ??? ??????? ????? ?????? (???? ?? ???? ??? ??? ???? ??? ????? ?? ?? ????? ???? ????? ??????? ??????? ??????? ??????? ??? ???? ??? ?? ????? ????? extrapc ?? ???? ??? subsilver2 ???? ?????? ????? ???? ??? ??? ??? ?????? ??????? ???? ?? ??? ??????? ????? ?????? ?? ??????? ?? ????? ??? ????? ??????)
1- ????? ?? ???? (??????)
2-????? ????? ???????? ??? ????? (??????? ??? ????)
3-????? ??????? ??? ??????? (???? ????? ?? ?????? ???)
4-????? ??????? ??? ???? (???? ???? ?? ??? ???????) ?????? ?? ????? ??? ?? ??? ?? ??? ?????????
???? ??????? ???? ????? ?????? ??????? ?? ??????? ??????? (?????? ?????? ) ??????? ???? ??? ?????? ?? ????? ????? ???? ??????? ???? ??? ??? function ? viewtopic_body ??????
????? ??? ?????? ????? ? ??????? ??????? ??? ????? ????? ??????? ???? ???? ???? ??? subsilver2 ????? ??? ???? ???? ????? ??????? ????? ??? ?????? ????? ???????
-????? ??????? ????????? ??? ???? ??? zip
-???? ?????? ?? ???? ftp
????: ?????? ??? ???? ??????? ???? ?????? subsilver2 ????? ?? 4 ????? ?????? ???
style.cfg ? theme.cfg ? imageset.cfg ? template.cfg ???? ?????? ?????? ??? ???? ??? ??? ?????? ??? 3.02 ??? 3.03 ??? ??????? ?? ?????? ???? ????????? ????? ???????
?????: ??? ???? ar (???? ????? ???????) ?????? ???? ?????? phpBBArabia ?? ??????? ?????? ??? ????? ??? ?????? ?? ???? ??????? ??????? ???? language
4-?????? ?????? ??? ?????? ??? ??????? ??? ???? http://www.xxx.com/forum/install
???? ??? ???? ??????? ?? ???? ??????? ????? ????? ?? ???? ??????? ???????? ???? ????? ??????? ?????? ??????? ???? ???? install
???? ????? ????? ????? ?????? ????? ??????? ?? ????? ????? extrapc ???? ?????? ???? ??? ??? ?? ???? ???????? ?????? ???? ????? subsilver2 ??? ?????
- A7bk.Ya.Allah
- مشاركات: 608
- مكان: الولايات المتحده
SQL ERROR [ mysql4 ]
Unknown column 't.template_inherits_id' in 'field list' [1054]
SQL
SELECT s.style_id, t.template_storedb, t.template_path, t.template_id, t.bbcode_bitfield, t.template_inherits_id, t.template_inherit_path, c.theme_path, c.theme_name, c.theme_storedb, c.theme_id, i.imageset_path, i.imageset_id, i.imageset_name FROM phpbb_styles s, phpbb_styles_template t, phpbb_styles_theme c, phpbb_styles_imageset i WHERE s.style_id = 1 AND t.template_id = s.template_id AND c.theme_id = s.theme_id AND i.imageset_id = s.imageset_id
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal_mysql->sql_error()
FILE: includes/session.php
LINE: 1558
CALL: dbal_mysql->sql_query()
FILE: index.php
LINE: 26
CALL: user->setup()???? ???????? ?? ???? ???????? ??????? ????? ?? ????
?????? ?????A7bk.Ya.Allah كتب:????? ??? ??? ??????? ??????
naserhaq كتب:?????? ?????
????? ??????? ????? ???? ?? ?????? ??? ?? ???كود: تحديد الكل
SQL ERROR [ mysql4 ] Unknown column 't.template_inherits_id' in 'field list' [1054] SQL SELECT s.style_id, t.template_storedb, t.template_path, t.template_id, t.bbcode_bitfield, t.template_inherits_id, t.template_inherit_path, c.theme_path, c.theme_name, c.theme_storedb, c.theme_id, i.imageset_path, i.imageset_id, i.imageset_name FROM phpbb_styles s, phpbb_styles_template t, phpbb_styles_theme c, phpbb_styles_imageset i WHERE s.style_id = 1 AND t.template_id = s.template_id AND c.theme_id = s.theme_id AND i.imageset_id = s.imageset_id BACKTRACE FILE: includes/db/mysql.php LINE: 174 CALL: dbal_mysql->sql_error() FILE: includes/session.php LINE: 1558 CALL: dbal_mysql->sql_query() FILE: index.php LINE: 26 CALL: user->setup()
??? ??? ??????? 3.01 ??? ???? ??????? ?? ??? 30.2 ??? ??? 3.03
?? ????? ??? ?????? ????? ???? ?????? ??? ??????? ??? 3.03
http://www.phpbbarabia.com/community/vi ... 32&t=32286
1- ????? 3.0.2
2- ???? ??? ??????? ????????? ??? 3.0.3 ???? ?????? ????? ???????? ??? (?? ???? ?? ???? ???????? ???)
3- ???? ??? ??????? ????????? ??? 3.0.4 ???? ?????? ????? ???????? ?? ????? ??????? ???? ?????????? ?? ???????
?? ???? ?? ??? ?? ??????? ????????? ?????? ???????? ??? ??? 3.0.3 ..?? (??????? ??????? ??? ??? ??????? ??? 3.0.4)
1- ????? 3.0.2
