النقاش حول الترقيه الى 3.0.5
Scout4all
مشاركات: 955
مكان: مصر- اسكندرية
?????? ??? ??????? ??? 3.0.5
مشاركةبواسطة Scout4all » الأحد مايو 31, 2009 8:58 pm
?????? ?????? ??? ?????? ?? ??? ??????? ??? ??????? ?? phpBB3.0.5
????? ?????? ???????? : http://www.phpbbarabia.com/community/vi ... 34&t=34039
?? ????? ??? ??????? ????????????? ?????? ??????? ???????? ?????? 3.0.4
http://cid-53a717c23c781701.skydrive.li ... dition.zip
??? ????? ??????? ????????????? ?????? Extra PC
Extra PC كتب:??? ??? ???? ?????? ???????
???? ???? ?????? ??? ???? ?????? ????? ??????? ?? ?????? 3.0.4 ??? 3.0.5
http://www.phpbbarabia.com/community/vi ... 32&t=34057
New features and important changes are:
    * Added and refined CAPTCHA options to better protect against new version of CAPTCHA crackers.
    * Added an option to the registration screen to allow users to refresh the displayed CAPTCHA.
    * Performance improvements for native fulltext search.
    * Added a new search option. The admin can define the maximum number of words allowed to search for. This option gives control about the maximum search load.
    * Search indexing should no longer stall for some installations.
    * Conflicting files are able to be downloaded now within the automatic updater for manual inspection.
    * The database updater now checks for an incompatible database schema in case the database version got updated. The admin will be notified about possible solutions and repair scripts.
    * We now set the connection encoding for MySQL versions 4.1.0 to 4.1.2. This may fix some conversion issues with special characters.
    * Language pack authors now see errors/notices within their language pack if they enabled DEBUG_EXTRA.
    * Flash files now display again after update to flash player 10.
Changes since 3.0.4:
    * [Fix] Delete user entry from ban list table upon user deletion (Bug #40015 - Patch by TerraFrost)
    * [Fix] Posts incremented for multiple approval of the same topic (Bug #40495 - Patch by TerraFrost)
    * [Fix] Missing end " in quote bb tag deletes text (Bug #40565 - Patch by TerraFrost)
    * [Fix] Friend/foe system displays posts made by foes while composing (Bug #40325 - Patch by TerraFrost and Highway of Life)
    * [Fix] Check forum_image whether it exists (Bug #39005 - Patch by TerraFrost)
    * [Fix] The sql query in acp_users.php lacks a condition (Bug #40275 - Patch by grimskies)
    * [Fix] Added missing read permission information for some phpbb_chmod() calls
    * [Fix] Correctly display future dates (Bug #38755)
    * [Fix] Fix guest/bot session problems with apache authentication plugin (Bug #41085)
    * [Fix] Whois now works reliably for RIRs other than APNIC and RIPE. (Bug #40085)
    * [Fix] Correctly convert Niels' Birthday MOD to the date format used in phpBB3. (Bug #32895)
    * [Fix] Changed the success message when requesting a new password to be more accurate. (Bug #41405)
    * [Fix] Add missing anti-abuse email headers to acp_inactive.php and ucp_resend.php.
    * [Fix] Only remind users in the correct inactive states depending on the board account activation level.
    * [Fix] Various XHTML mistakes in prosilver, subsilver2 and the ACP. (Bugs #41745, #42265 - Patch by nickvergessen, #38465, #43015)
    * [Fix] Log password changes via password reset function. (Bug #41365)
    * [Fix] Poll, negative durations generate error (Bug #41295 - Patch by TerraFrost)
    * [Fix] Visibility of custom field on registration is incorrectly controlled by setting "display" (Bug #41385 - Patch by Eelke and fade2gray)
    * [Fix] Smilies in username are misparsed on [quote=""] (Bug #41955 - Patch by TerraFrost)
    * [Fix] Deleting all posts in a topic - bad redirect (Bug #41705 - Patch by TerraFrost)
    * [Fix] Deleted users still appear logged in (Bug #41985 - Patch by TerraFrost)
    * [Fix] Removed redundant code and unnecessary queries in forum management. (Bug #42265 - Patch by nickvergessen)
    * [Fix] Correct mbstring regular expression for the allowable username characters, only affects USERNAME_LETTER_NUM_SPACERS. (Bug #42325)
    * [Fix] Fix infinite loop in message handler if cache directory is not writable. (Bug #38675)
    * [Fix] While post is awaiting approval it can still be edited even though it can not be seen (Bug #41435 - Patch by TerraFrost)
    * [Fix] Fix imageset editing for retaining and correctly setting dimensions for images, as well as displaying correct settings for first page load.
    * [Fix] Use OS-specific line endings for mail headers. (related to Bug #42755)
    * [Fix] Hide font size options which are bigger than the allowed size in the editor. (Bug #42615 - Patch by nickvergessen)
    * [Fix] Better thumbnail quality with imagemagick. (Bug #42565)
    * [Fix] Fix download count increments for image attachments without corresponding thumbnails. (Bug #42505)
    * [Fix] Fix wrong bot ip check if bot ip was wrongly entered by admin. (Bug #42485)
    * [Fix] Fix javascript errors in simple header (prosilver) by adding forum_fn.js and the corresponding variables. (Bug #42135)
    * [Fix] Set connection encoding for MySQL versions 4.1.0 to 4.1.2. This may fix some conversion issues with special characters. (Bug #41805)
    * [Fix] Deleting private message attachments could delete post attachments. (Bug #42815)
    * [Fix] Do not suppress PHP notices/errors in language packs if DEBUG_EXTRA mode enabled. (Bug #41485)
    * [Fix] Flash files do not display anymore after update to flash player 10 (Bug #41315)
    * [Fix] Use FQDN for SMTP EHLO/HELO command. (Bug #41025)
    * [Fix] Mass Email works again for users with empty jabber address but notification set to 'both'. (Bug #39755)
    * [Fix] Fix race condition for updating post/topic/etc. counter. (Reported by BartVB)
    * [Fix] Fix duplicate creation of acl options in acl_add_options() under certain conditions. (Bug #38385, #40225)
    * [Fix] Cancel when replying to global announcement redirects to first forum - not to the current forum (Bug #41225 - Patch by TerraFrost)
    * [Fix] Cursor Jumps on New Topic in IE (Bug #42455 - Patch by TerraFrost)
    * [Fix] Add indicator to be used in code if session was created (user visits the site for the first time).
    * [Fix] Correctly count topic views for guests visiting the website the first time by entering the topic directly (Bug #43445)
    * [Fix] Fix bug in postgresql db layer for LIMIT ALL clauses (Reported by JRSweets)
    * [Fix] Sort backups by date, newest first (Bug #14818)
    * [Fix] Prevent incomplete backups stored if option "store and download" is selected and admin cancel download by removing the option. (Bug #20325)
    * [Fix] Enforce correct case for template variables
    * [Fix] Set topic_last_view_time on post/reply/edit to circumvent race conditions in auto prune and false removal of topics for manual forum prune (Bug #18055, #43515)
    * [Fix] Correctly split long subject lines according to the used RFC. This fixes extra spaces within long subjects. (Bug #43715)
    * [Fix] Fix skipping messages if using next/prev PM in history links. (Bug #22205)
    * [Fix] Messenger now also able to use a custom language path. (Bug #36545)
    * [Fix] PM Export uses ISO 8601 date now. (Bug #32645)
    * [Fix] Apply append_sid() to newest/latest post links in viewforum/search and UCP main module. (Bug #26815)
    * [Fix] Do not create thumbnail if thumbnail would've the same size as the original image. (Bug #30725)
    * [Fix] Ability to vote in poll is now required for the ability to change existing vote. (Bug #38925)
    * [Fix] Search for 'topic title only' and 'first post' should work again for non-mysql dbms. (Bug #40605)
    * [Fix] Make sure additional information for accessibility is always exposed to screen readers (Bug #44335 - Patch by MarcoZ)
    * [Fix] Approving a topic when some of the posts within that topic have already been approved (Bug #42585 - Patch by TerraFrost)
    * [Fix] Online status shown when post hidden (Bug #35505 - Patch by Raimon)
    * [Fix] memberlist.php display formating can be distorted by posting long URL for website (Bug #36675 - Patch by TerraFrost)
    * [Fix] Display the online status of hidden users to users with the u_viewonline permission when viewing PMs.
    * [Fix] "Select all" selects much too much in Opera (Bug #42885 - Patch by TerraFrost and ToonArmy)
    * [Fix] Correct calculation of source/target forum statistics if mass moving topics with global announcements (Bug #44545)
    * [Fix] Fix column handling in db updater, custom profile fields and db tools for firebird DBMS (Bug #44555)
    * [Fix] IE8 textarea issues (Bug #43305)
    * [Fix] Prevent accounts from being activated by users when admin activation is turned on and the correct activation key is known.
    * [Fix] Allow the installer to operate under PHP 5.3. (Bug #45255)
    * [Change] Default difference view is now 'inline' instead of 'side by side'
    * [Change] Added new option for merging differences to conflicting files in automatic updater
    * [Change] Add link to user profile in the MCP for user notes and warn user.
    * [Change] Add IN_PHPBB check to generated cache files. (Reported by bantu)
    * [Change] Add topic icons to prosilver UCP main and subscribed templates (Bug #42735 - Patch by Raimon)
    * [Change] Add unique key to ACL options table to prevent duplicate permission options. (Bug #41835)
    * [Change] Redirect to relevant MCP page of multi-page topic if accessing quickmod tools (Split option for example)
    * [Change] Performance improvements for native fulltext search (Patch by Paul)
    * [Change] Changed jumpto() JS function to be more fail-safe. (But #27635 - Patch by peterkclee)
    * [Feature] Added new options for visual confirmation.
    * [Feature] Allow download of conflicting file for later reference in automatic updater
    * [Feature] Allow translation of custom BBCode help messages. (Patch by bantu)
    * [Feature] db_tools now support create table and drop table.
    * [Feature] Database updater checks for incompatible db schema (MySQL 3.x/4.x against MySQL 4.1.x/5.x/6.x)
    * [Feature] New search option: Maximum number of words allowed to search for.
    * [Sec] Only use forum id supplied for posting if global announcement detected. (Reported by nickvergessen)
[/b]
phpBB-Styes-code-3.0.4_to_3.0.5.zip
ملف به تعليمات تحديث الاستايلات من 3.0.4 الى 3.0.5 لمن يمكلك استايلات غير الاساسيه
(6.92 KiB) حُمِّل 574 مرةً
آخر تعديل بواسطة Scout4all في الأحد يونيو 07, 2009 3:35 pm، تم التعديل 9 مرات في المجمل.
خالد0
مشاركات: 183
اشترك في: الثلاثاء مايو 04, 2004 10:06 pm
مكان: Doha, Qatar
مشاركةبواسطة خالد0 » الأحد مايو 31, 2009 11:30 pm
http://www.phpbb.com/community/viewtopi ... &t=1625005
sembawyo
مشاركات: 118
اشترك في: الاثنين إبريل 20, 2009 11:22 am
مشاركةبواسطة sembawyo » الأحد مايو 31, 2009 11:46 pm
Scout4all
مشاركات: 955
مكان: مصر- اسكندرية
مشاركةبواسطة Scout4all » الاثنين يونيو 01, 2009 12:10 am
--???? ??????? ????????????? ? ?? ???? ???? ????? ??? phpbb ? ???? ????????? ??? ??????? ??????? ??? ?????? ? ??????? ??????? ? ?? ???? ?????? ???? ??????? ??? ??? ????? ??????? ? ?????????? ??? ???????? prosilver-subsilver????? ??? ??????? ????????????? ?? ???
http://www.phpbb.com/downloads/olympus.php?update=1
http://www.phpbb.com/files/release/phpB ... hanges.zip
sembawyo
مشاركات: 118
مشاركةبواسطة sembawyo » الاثنين يونيو 01, 2009 12:46 am
Scout4all
مشاركات: 955
مكان: مصر- اسكندرية
مشاركةبواسطة Scout4all » الاثنين يونيو 01, 2009 1:00 am
sembawyo كتب:??? ?? ??????? ????? ??? ?????? ??? ??????? ???????
lovevoice
مشاركات: 340
اشترك في: الأحد سبتمبر 23, 2007 5:46 am
مشاركةبواسطة lovevoice » الاثنين يونيو 01, 2009 7:00 am
????? ??????? ???????? ?? ??? ??????? http://www.phpbbarabia.com/community/vi ... 47#p177647 ???? ??? ???????
?? ??? http://www.ohloh.net/p/phpbb/download?f ... _3.0.5.zip
lovevoice
مشاركات: 340
مشاركةبواسطة lovevoice » الاثنين يونيو 01, 2009 7:18 am
1- ??? ????? ????? ???????? ?? ???? ??? ???? ??????? ????? ?????
2- ?? ??????? ?????? ?? ???? ?????? ??? ????? ??? ?????? ???? ?? ?? ???? ??????? 3.0.4 ??? ???? ??? ???? ???? ??? ???? ????? , ?? ??? ??????? ????? ?? 3.0.5 ????? ?? ???? ????? ??????? ??? ?????? ??????? ?
مشاركةبواسطة Garebooo » الاثنين يونيو 01, 2009 7:33 am
sembawyo
مشاركات: 118
مشاركةبواسطة sembawyo » الاثنين يونيو 01, 2009 8:00 am
Scout4all
مشاركات: 955
مكان: مصر- اسكندرية
مشاركةبواسطة Scout4all » الاثنين يونيو 01, 2009 10:50 am
sembawyo كتب:??? ?? ???? ???? ?? ?????? ???????? ???? ?????? ???? ????? ??? ???? ?????
http://sourceforge.net/project/download ... irror=garr
?????http://www.wampserver.com
http://www.phpbbarabia.com/community/vi ... 70&t=32652
آخر تعديل بواسطة Scout4all في الاثنين يونيو 01, 2009 11:21 am، تم التعديل مرة واحدة.
q8ieng
مشاركات: 371
مكان: C:\Windows
مشاركةبواسطة q8ieng » الاثنين يونيو 01, 2009 11:21 am
???? ?????? ??????? ???? ???? ?????? ????? forums ?? phpbb :D
Extra PC
مشاركات: 283
مشاركةبواسطة Extra PC » الاثنين يونيو 01, 2009 11:22 am
غريب العراق
مشاركات: 88
اشترك في: الأحد نوفمبر 30, 2003 7:13 pm
مشاركةبواسطة غريب العراق » الاثنين يونيو 01, 2009 1:35 pm
bader7
مشاركات: 1
اشترك في: الأحد أغسطس 17, 2008 9:58 pm
مشاركةبواسطة bader7 » الاثنين يونيو 01, 2009 2:25 pm
