[نقاش] Support Toolkit 1.0.3
melattar
- مشاركات: 2
- اشترك في: السبت يوليو 03, 2010 6:19 pm
[????] Support Toolkit 1.0.0-pl1
smatel2007
- مشاركات: 63
- اشترك في: الأربعاء أكتوبر 28, 2009 1:17 pm
- مكان: سوريا
Scout4all
- مشاركات: 955
- اشترك في: الخميس يوليو 06, 2006 4:20 pm
- مكان: مصر- اسكندرية
[????] Support Toolkit 1.0.2
???? ?????? ????? ????? ?????? 1.0.2
http://www.phpbb.com/community/viewtopi ... 29a4708933
http://www.phpbb.com/customise/db/official_tool/stk/
Updating:
When updating from any older Support Toolkit version first delete the old "stk/" directory before uploading the new version.
New features:
With this release the Support Toolkit is extended with the following new features.
* [Add] Added a way to force the BOM sniffer to check all files within the phpBB path. (Bug #62186)
* [Add] Added Emergency Repair Kit. (Bug #62202)
* [Add] Added a SRT generator, which tries to pre-fill some important pieces of information. (Bug #62280)
Changes:
Besides new features, this release includes some larger changes to system.
* [Change] Use a whitelist of files that will be ran through the BOM sniffer. (Bug #62183)
* [Change] The BOM sniffer will create a backup the files in which it found issues.
* [Change] Database won't run the same check twice when no changes where detected for a given step.
* [Change] Try to overwrite the PHP time and memory limits, this might prevent some issues.
Bug fixes:
This release fixes the following bugs.
* [Fix] The style dir critical repair tool doesn't recognise non-installed styles. (Bug #62130)
* [Fix] In some environments the database cleaner breaks when no changes are found. (Bug #62180, Patch by VSE)
* [Fix] Force sorting when loading database cleaner data files. (Bug #62180, Patch by Noxwizard)
* [Fix] Correctly handle the restore deleted users tool when there are no deleted users. (Bug #62181)
* [Fix] Removed some php ? 5.0.0 code.
* [Fix] Automatic critical repair tools wheren't ran. (Bug #62194)
* [Fix] Reparse all BBCodes fail. (Bug #62203)
* [Fix] Private message senders get changed after merge users tool has merged PMs. (Bug #62247, Patch by ToonArmy)
* [Fix] A couple of language related issues.
* [Fix] Log the user out when using the STK logout method and using the phpBB buildin login method.
* [Fix] Fixed an issue that broke backward compatibility with phpBB versions prior to 3.0.3.
* [Fix] Correctly re-add all modules when "reset modules" in the database cleaner is ran. (Bug #62429)
* [Fix] Make sure that the STK is able to run when the user has UMIL < 1.0.3 installed. (Bug #62430)
* [Fix] Prevent bots from being buplicated in the user groups table when the database cleaner is ran. (Bug #62434)
* [Fix] Maintain the user signature options when reparsing signatures. (Bug #62451)
* [Fix] Remove PHP 5 only code from the Merge users tool. (Bug #62458)
آخر تعديل بواسطة Scout4all في الأحد نوفمبر 21, 2010 9:17 am، تم التعديل مرة واحدة.
Scout4all
- مشاركات: 955
[????] Support Toolkit 1.0.2.1-PL1
???? ?????? ????? ????? ?????? 1.0.2.1
http://www.phpbb.com/community/viewtopi ... &t=2111079
New Features:Changes:
- Added a tool to find potentially dangerous flash BBCodes in posts, PMs and signatures.
- Modify Reparse BBCode tool to allow user to specify post IDs and PM IDs to reparse.
- Add support for phpBB 3.0.8.
Bug fixes:
- Database cleaner file 3_0_6.php corrupted. (Bug #62484)
آخر تعديل بواسطة Scout4all في الأحد نوفمبر 21, 2010 9:16 am، تم التعديل مرة واحدة.
Scout4all
- مشاركات: 955
???? ?????? ????? ????? ?????? 1.0.2.1PL1
http://www.phpbb.com/community/viewtopi ... #p12900268
Bug fixes:
- Wrong constant in the flash checker. (Bug #62497)
JAWAD94
- مشاركات: 669
- مكان: سوريا بقلب مدينة حلب
?????? ????? ????? ??????? ?? ?????? ????? ????? ?????? 1.0.2.1-PL1 ?? ???????? ...
?????? ??? ?????? ... ???? ???????? ????? ?????? ?????? phpBB 3.0.8
ليس لديك الصلاحية لمشاهدة المرفقات
king070
- مشاركات: 54
- اشترك في: الجمعة نوفمبر 24, 2006 12:45 pm
??? ??? ?? ??? ?????? ?? ??????? ????? ???? ????JAWAD94 كتب:?????? ????? ????? ??????? ?? ?????? ????? ????? ?????? 1.0.2.1-PL1 ?? ???????? ...
JAWAD94
- مشاركات: 669
???? ...king070 كتب:??? ??? ?? ??? ?????? ?? ??????? ????? ???? ????JAWAD94 كتب:?????? ????? ????? ??????? ?? ?????? ????? ????? ?????? 1.0.2.1-PL1 ?? ???????? ...
?????? ????? en/tools/main/srt_generator.php ?? ar/tools/main/srt_generator.php
Scout4all
- مشاركات: 955
[????] Support Toolkit 1.0.3
?? ????? ?????? 1.0.3 ?? ?????? ???? ????? 10 ?????? 2011
http://www.phpbb.com/community/viewtopi ... &t=2120787
king070
- مشاركات: 54
FaresNB
- مشاركات: 1720
- اشترك في: الأحد مارس 11, 2007 11:32 pm
- مكان: قطر
king070
- مشاركات: 54
king070
- مشاركات: 54
???? ???? ????? ???? ????? ??????? http://www.cafe2arab.co.cc/stk/ . ???? ?? ?????? ??????? ?? ??? ?????? ????? ??? ?????.
almohsin
- عضو متميز
- مشاركات: 215
- اشترك في: الخميس إبريل 14, 2005 6:00 am
adm/index.php
adm/index.php
'S_CONTENT_FLOW_END' => ($user->كود: تحديد الكل
'S_CONTENT_FLOW_END' => ($user->lang['DIRECTION'] == 'ltr') ? 'right' : 'left',????? ???? ???? ?????
//-- Support Toolkit
//-- Add:
'U_STK_INDEX' => append_sid("{$phpbb_root_path}stk/index.$phpEx"),
//-- End Support Toolkit
آخر تعديل بواسطة almohsin في الاثنين فبراير 21, 2011 4:59 am، تم التعديل 3 مرات في المجمل.
سلام ومحبة لجميع الطيبين
king070
- مشاركات: 54
المتصفحون للمنتدى الآن: CommonCrawl Bot, DotNetDotCom.org Bot وزائر واحد
