هاك المجلة Board3
??? ?????? Board3
???? ?? ?????? : http://yallasharek.net/phpBB
[phpBB Debug] PHP Notice: in file /portal/includes/functions_version_check.php on line 38: include(./mods/board3_portal_check_version.php) [function.include]: failed to open stream: No such file or directory
[phpBB Debug] PHP Notice: in file /portal/includes/functions_version_check.php on line 38: include() [function.include]: Failed opening './mods/board3_portal_check_version.php' for inclusion (include_path='.')
[phpBB Debug] PHP Notice: in file /portal/includes/functions_version_check.php on line 42: call_user_func(board3_portal_check_version::version) [function.call-user-func]: First argument is expected to be a valid callback
??? ?????? Board3
viewtopic.php?f=32&t=40177&p=214401#p214401
???? ??? .htaccess ??? ???? ..
viewtopic.php?f=64&t=36461
??? ???? ????? ???? ?????? ?? ?????? ???????? ?????????? ???? ??? .htaccess ???? ???? ?? ????????? ???? ??? ????? .. ??? ?? ????? ????? ???? .. ?????? ???? ??? ????? ?????? ?? ??? ??? ??????? ????? ??????? ??????? ..
?? ???? ????? ??? ????? ???? ?????? ?? ?????? ?????? >>> http://www.skoshak8.com/portal.php
????? ??????? ???? ???? ??????? ?????? >>> http://www.skoshak8.com/phpbb3/index.php
# Uncomment the statement below if you want to make use of
# HTTP authentication and it does not already work.
# This could be required if you are for example using PHP via Apache CGI.
#<IfModule mod_rewrite.c>
#RewriteEngine on
#RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
#</IfModule>
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
DirectoryIndex portal.php index.php index.html index.htm
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
??? ?????? Board3
?? ???? ??? ????? ?? 3.9
- ابو عبد الودود
- مشاركات: 785
- مكان: ارض الله
??? ?????? Board3
???? كتب:?????? ?????
http://www.education-dz.com
??? ?????? Board3
??? ?????? Board3
??? ?????? Board3
- ابو عبد الودود
- مشاركات: 785
- مكان: ارض الله
?????? ??????? ?? ?????? 2.0.0 Board3
?? ????? ?????? ?????? ?? ?????? 2.0.0 ?? ??????? ???? ??????? ???? ??? ?? ?????? ?? ?? ?
http://www.board3.de/viewtopic.php?f=40&t=5477
- ابو عبد الودود
- مشاركات: 785
- مكان: ارض الله
??? ?????? Board3
?????? ?????? ????? ???? ???????Scout4all كتب:???? ??? portal.php ?? ???? ????? ???????pg4soft كتب:???? ??? ??? ????? ?????
http://forum.domain.com << ?????
http://www.domain.com << ??????
?????? ??? ?????? ???كود: تحديد الكل
$phpbb_root_path?=?(defined('PHPBB_ROOT_PATH'))???PHPBB_ROOT_PATH?:?'./';?
? ??? ???? ?? ???? ??? ?????? ?????? ?????كود: تحديد الكل
$phpbb_root_path?=?(defined('PHPBB_ROOT_PATH'))???PHPBB_ROOT_PATH?:?'./???????????/';?
???? ??? .htaccess ??? ?? ???? ????? ???????
? ??? ???كود: تحديد الكل
http://www.bnirdsarabic.com
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './http://www.birdsarabic.com/';
- محمود محمد
- مشاركات: 15
- اشترك في: الثلاثاء يناير 22, 2013 1:12 pm
??: ??? ?????? Board3
?????? ???? ????? ??????? ????? Borard 2.0.2 ???? ?
