هاك موضوعات متشابهة
جريب فروت
مشاركات: 493
مشاركةبواسطة جريب فروت » الأربعاء مارس 03, 2010 10:51 am
????? ?????: 0.1.2
????? ?????: tas2580
???? ???????: http://www.phpbb-seo.de
???? ?????: samaBB
viewtopic.php
styles/prosilver/template/viewtopic_body.html
styles/subsilver2/template/viewtopic_body.html
language/ar/common.php
???? ??? viewtopic.php:
    page_header($user->lang['VIEW_TOPIC'] .' - ' . $topic_data['topic_title']);
        $sql= 'SELECT f.forum_id, f.forum_name, t.topic_id, t.topic_title, u.user_id, u.username, u.user_colour
           FROM ' . TOPICS_TABLE . ' t, ' . USERS_TABLE . ' u, ' . FORUMS_TABLE . " f
           WHERE MATCH (t.topic_title) AGAINST ('" . $db->sql_escape($topic_data['topic_title']) . "' IN BOOLEAN MODE)
           AND f.forum_id = t.forum_id
           AND u.user_id = t.topic_poster
           AND t.topic_id <> " . (int) $topic_data['topic_id'] . '
           GROUP BY t.topic_id';
        if ($result = $db->sql_query_limit($sql, 5))
        while($similar = $db->sql_fetchrow($result))
        if ($auth->acl_get('f_list', $similar['forum_id']))
        $similar_forum_url = append_sid('viewforum.php?f='.$similar['forum_id']);
        $similar_topic_url = append_sid('viewtopic.php?f='.$similar['forum_id'].'&t='.$similar['topic_id']);
        $similar_user = '<a style="color: #' .$similar['user_colour']. ';" href="' .append_sid('memberlist.php?mode=viewprofile&u='.$similar['user_id']). '">' .$similar['username']. '</a>';
        $template->assign_block_vars('similar', array(
        'TOPIC_TITLE' => $similar['topic_title'],
        'U_TOPIC' => $similar_topic_url,
        'USER' =>  $similar_user,
        'U_FORUM' => $similar_forum_url,
        'FORUM' => $similar['forum_name'])
# ???? ??? styles/prosilver/template/viewtopic_body.html:
    <!-- INCLUDE jumpbox.html -->
        <div class="forumbg" style="width: 100%; margin:0 auto">
        <span class="corners-top"><span></span></span>
        <div style="color: #FFFFFF; height: 20px;"><b>{L_SIMILAR_TOPICS}</b></div>
        <table border="0" class="bg1" width="100%">
        <!-- BEGIN similar -->
        <td width="40%"><a class="topictitle" href="{similar.U_TOPIC}">{similar.TOPIC_TITLE}</a></td>
        <td width="30%"><a class="topictitle" href="{similar.U_FORUM}">{similar.FORUM}</a></td>
        <td width="10%">{similar.USER}</td>
        <!-- END similar -->
        <span class="corners-bottom"><span></span></span>
# ???? ??? styles/subsilver2/template/viewtopic_body.html:
    <th colspan="3">{L_SIMILAR_TOPICS}</th>
# ???? ??? language/ar/common.php:
    'YOU_NO_NEW_PM'   => '?? ???? ????? ???? ????? ?? ????? ??????',
        'SIMILAR_TOPICS' => '??????? ???????',
[/b][/color]
مشاركةبواسطة Garebooo » الأربعاء مارس 03, 2010 2:18 pm
جريب فروت
مشاركات: 493
مشاركةبواسطة جريب فروت » الخميس مارس 04, 2010 2:59 pm
Garebooo كتب:???? ???? ??????? ??? ?? ???? ??????? ?????? ??? ???? ??? ????? ? ??? ????? ????
?? ??? ?????? ???? :D
جريب فروت
مشاركات: 493
مشاركةبواسطة جريب فروت » الأحد مارس 07, 2010 1:40 am
A.B.M.K
مشاركات: 2421
مكان: Germany
مشاركةبواسطة A.B.M.K » الأحد مارس 21, 2010 11:16 am
???? ??? styles/zajil/template/viewtopic_body.html
<!-- INCLUDE overall_footer.html -->
جريب فروت
مشاركات: 493
مشاركةبواسطة جريب فروت » الأربعاء مارس 31, 2010 12:58 pm
مشاركةبواسطة مهند قمرة » الأحد إبريل 04, 2010 12:58 pm
awthah
مشاركات: 401
مكان: اليمن -صنعاء
مشاركةبواسطة awthah » الأربعاء إبريل 14, 2010 5:49 pm
http://www.englab-su.com/bb
نوع الستايل :- prosilver
اللهم احفـــظ اليمن ...
gino
مشاركات: 370
مشاركةبواسطة gino » الخميس إبريل 15, 2010 5:28 pm
/// ??? SQL
ALTER TABLE phpbb_topics ADD FULLTEXT (topic_title);
/// ???? viewtopic.php
// Output the page
page_header($topic_data['topic_title'], true, $forum_id);
// Begin similar topics
$sql_array = array(
	'SELECT'	=> 'f.forum_id, f.forum_name, t.topic_id, t.topic_title, u.user_id, u.username, u.user_colour, t.topic_replies, t.topic_views',
	'FROM'		=> array(
		TOPICS_TABLE	=> 't',
	'LEFT_JOIN'	=> array(
		array(
			'FROM'	=>	array(USERS_TABLE	=> 'u'),
			'ON'	=> 'u.user_id = t.topic_poster'
		array(
			'FROM'	=>	array(FORUMS_TABLE	=> 'f'),
			'ON'	=> 'f.forum_id = t.forum_id'
	'WHERE'		=> "MATCH (t.topic_title) AGAINST ('" . $db->sql_escape($topic_data['topic_title']) . "' ) >= 0.5
		AND t.topic_status <> " . ITEM_MOVED . '
		AND t.topic_id <> ' . (int) $topic_data['topic_id'],
	'GROUP_BY'	=> 't.topic_id',
	'ORDER_BY'	=> 't.topic_last_post_time DESC',
$sql = $db->sql_build_query('SELECT', $sql_array);
		if ($auth->acl_get('f_read', $similar['forum_id']))
			$similar_forum_url	= append_sid("{$phpbb_root_path}viewforum.$phpEx", "f=" . $similar['forum_id']);
			$similar_topic_url	= append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=" . $similar['forum_id'] . '&t=' . $similar['topic_id']);
			$similar_user		= get_username_string('full', $similar['user_id'], $similar['username'], $similar['user_colour'], $similar['username']);
				'VIEWS'				=> $similar['topic_views'],
				'REPLIES'				=> $similar['topic_replies'],
// End Similar Topics
/// ???? styles/prosilver/template/viewtopic_body.html
<!-- IF .similar -->
<br />
<div class="forabg">
		<table class="table1" cellspacing="1" >
		<thead>
		<th style="width: 56%;"><b>{L_SIMILAR_TOPICS}</b></th>
		<th style="width: 15%;"><b>{L_FORUM}</b></th>
		<th style="width: 15%;"><b>{L_AUTHOR}</b></th>
		<th style="width: 7%;"><b>{L_REPLIES}</b></th>
		<th style="width: 7%;"><b>{L_VIEWS}</b></th>
		</thead>
		<tbody>
			<td class="bg2" valign="center">
			<a href="{similar.U_TOPIC}" class="topictitle"><center>{similar.TOPIC_TITLE}</center></a>
			<a href="{similar.U_FORUM}"><center>{similar.FORUM}</center></a>
			<center>{similar.USER}</center>
			<center>{similar.REPLIES}	</center>
			<center>{similar.VIEWS}	</center>
		</tbody>
<br />
<br />
<h3>{L_SIMILAR_TOPICS}</h3>
<div class="post bg1">
	<div class="inner">
				<a href="{similar.U_TOPIC}" class="topictitle">{similar.TOPIC_TITLE}</a><br />
				{L_FORUM}: <a href="{similar.U_FORUM}">{similar.FORUM}</a><br />
				{L_AUTHOR}: {similar.USER}<br />
				{L_REPLIES}: {similar.REPLIES}<br />
				{L_VIEWS}: {similar.VIEWS}<br /><br />
			<div class="back2top"><a href="#wrap" class="top" title="{L_BACK_TO_TOP}">{L_BACK_TO_TOP}</a></div>
<br />
/// ???? language/ar/common.php
        'SIGNATURE'                                        => '???????',
		'SIMILAR_TOPICS'				=> '?????? ??????',
???????? ?????? ???? awthah
???? ??? ???? ????.. ??? ????? ???? ?? ???? ??????? ?? ????? ??? ?????? ??? ??????? ?? ???? ??? ???????? ???????? ???? ?????.. :D
FaresNB
مشاركات: 1720
مكان: قطر
مشاركةبواسطة FaresNB » الجمعة إبريل 16, 2010 10:19 am
?? ?????? ??? ????? ?? ?????? , ??? ???????? ????? ??? ?? ?????? ? ??? ??? ??????? ?? ??? ???? ???????? ?? ??????? ???? , ???? ?? 2000 ????
خطير
مشاركات: 11
اشترك في: الخميس مارس 18, 2010 12:02 am
مشاركةبواسطة خطير » الاثنين مايو 10, 2010 6:48 pm
جريب فروت
مشاركات: 493
مشاركةبواسطة جريب فروت » الثلاثاء مايو 11, 2010 5:49 pm
FaresNB كتب:?? ?????? ??? ????? ?? ?????? , ??? ???????? ????? ??? ?? ?????? ? ??? ??? ??????? ?? ??? ???? ???????? ?? ??????? ???? , ???? ?? 2000 ????
جريب فروت
مشاركات: 493
مشاركةبواسطة جريب فروت » الثلاثاء مايو 11, 2010 5:51 pm
???? كتب:??? ????? ???? ??? .. ?????? ????? ????? ???? ?? ??????? ??????? ???? ???? ???
خطير
مشاركات: 11
مشاركةبواسطة خطير » الأحد مايو 16, 2010 10:21 pm
??? ??? ?? ???? ????? ?? ???? ???? ????? ..??? ???? ??? SQL ??? ???? ???
mohamed89
مشاركات: 549
مكان: Egypt
مشاركةبواسطة mohamed89 » الخميس يونيو 24, 2010 2:51 am
المتصفحون للمنتدى الآن: GoogleAdsenseBot, GoogleBot وزائران
