تصغير صور الأعضاء والمجموعات الشخصية تلقائياً
JAWAD94
مشاركات: 669
مكان: سوريا بقلب مدينة حلب
مشاركةبواسطة JAWAD94 » السبت مارس 20, 2010 2:40 am
???? ?????: doviet dev@doviet.net
???? ?????: 0.0.4b
???? ?????: JAWAD94
???? ??????? ?????????: 3.0.1 (????? ?? ????? 3.0.6 ????? 100% )
??? ???????: 15 ?????
??????: ??? ????? ????? ????? ????? ???????? ??? ?????? JPJ ??? ??? ???? ?????
includes/functions_upload.php
includes/acp/acp_board.php
includes/acp/acp_groups.php
includes/acp/acp_users.php
includes/ucp/ucp_groups.php
includes/ucp/ucp_profile.php
language/ar/acp/board.php
styles/prosilver/template/ucp_avatar_options.html
styles/subsilver2/template/ucp_profile_avatar.html
????? ?????: includes/dv_functions_image.php ?? ????????
?????? ????? ???? ????? ??????? ???? ?????? ?? ??? ???? http://www.phpbb.com/mods/
includes/dv_functions_image.php to includes/
???? ??? ????? ?? ????? ???????? SQL
INSERT INTO `phpbb_config`(`config_name`, `config_value`, `is_dynamic`) VALUES ('avatar_auto_resize', 0, 1);
????:includes/functions_upload.php
if (!defined('IN_PHPBB'))
	exit;
require($phpbb_root_path . 'includes/dv_functions_image.' . $phpEx);
	function move_file($destination, $overwrite = false, $skip_image_check = false, $chmod = 0666)
		global $user, $phpbb_root_path;
, $config
				// Make sure the dimensions match a valid image
				if (empty($this->width) || empty($this->height))
					$this->error[] = $user->lang['ATTACHED_IMAGE_NOT_IMAGE'];
				else if($config['avatar_auto_resize']
				&& (request_var('mode', '')=='avatar'
				|| (request_var('i', '')=='groups' && request_var('mode', '')=='manage')
				|| request_var('i', '')=='users'))
					$img = new Image($this->destination_file);
					$img->set_max_width($config['avatar_max_width']);
					$img->set_max_height($config['avatar_max_height']);
					$img->set_max_filesize($config['avatar_filesize']);
					if($img->resize())
						$img_infos = getimagesize($this->destination_file);
						$this->width = $img_infos[0];
						$this->height = $img_infos[1];
		$this->additional_checks();
		if(!$config['avatar_auto_resize']
		|| request_var('mode', '')!='avatar'
		|| (request_var('i', '')!='groups' && request_var('mode', '')=='manage')
		|| request_var('i', '')!='users')
	function fileupload($error_prefix = '', $allowed_extensions = false, $max_filesize = false, $min_width = false, $min_height = false, $max_width = false, $max_height = false)
		global $config;
		|| (request_var('mode', '')=='manage' && request_var('i', '')=='groups')
		$max_filesize = 1048576;
????:includes/acp/acp_board.php
						'avatar_max'			=> array('lang' => 'MAX_AVATAR_SIZE',		'validate' => 'int:0',	'type' => 'dimension:3:4', 'explain' => true, 'append' => ' ' . $user->lang['PIXEL']),
						'avatar_auto_resize'	=> array('lang' => 'AVATAR_AUTO_RESIZE',	'validate' => 'bool',	'type' => 'radio:yes_no', 'explain' => true),
????: includes/acp/acp_groups.php
							'AVATAR_MAX_FILESIZE'	=> $config['avatar_filesize'],
							'AVATAR_MAX_FILESIZE'	=> ($config['avatar_auto_resize'] && request_var('mode', '')=='avatar') ? '' : $config['avatar_filesize'],
????: includes/acp/acp_users.php
????: includes/ucp/ucp_groups.php
????: includes/ucp/ucp_profile.php
					'AVATAR_SIZE'	=> $config['avatar_filesize'],
					'AVATAR_SIZE'	=> ($config['avatar_auto_resize'] && request_var('mode', '')=='avatar') ? '' : $config['avatar_filesize'],
					'S_FORM_ENCTYPE'	=> ($can_upload) ? ' enctype="multipart/form-data"' : '',
					'S_AVATAR_AUTO_RESIZE'	=> $config['avatar_auto_resize'] ? true : false,
????: language/ar/acp/board.php
	'MIN_AVATAR_SIZE'				=> '???? ??????? ????? ???????',
	'MIN_AVATAR_SIZE_EXPLAIN'		=> '???????? ? ????? ???????',
	'AVATAR_AUTO_RESIZE'			=> '????? ????? ????????',
	'AVATAR_AUTO_RESIZE_EXPLAIN'	=> '???? ?????? ????? ???????? ????? ??? ??? ???? ?? ????????? ????? ?? ?????? ????? ?????.',
????:styles/prosilver/template/ucp_avatar_options.html
		<dt><label>{L_CURRENT_IMAGE}:</label><br /><span>{L_AVATAR_EXPLAIN}</span></dt>
		<dt>
			<!-- IF not S_AVATAR_AUTO_RESIZE -->
			<br />
		</dt>
????: styles/subsilver2/template/ucp_profile_avatar.html
	<td class="row1" width="35%"><b class="genmed">{L_CURRENT_IMAGE}: </b><br /><span class="gensmall">{L_AVATAR_EXPLAIN}</span></td>
	<!-- ENDIF --></td>
[/b]
dv_functions_image.zip
(1.87 KiB) حُمِّل 473 مرةً
آخر تعديل بواسطة JAWAD94 في الأحد مارس 21, 2010 2:13 pm، تم التعديل مرة واحدة.
FaresNB
مشاركات: 1720
مكان: قطر
مشاركةبواسطة FaresNB » السبت مارس 20, 2010 9:58 pm
- ???? ??? ??????? ?????? ?? ???????? ??? ?? ??? txt
المتصفحون للمنتدى الآن: GoogleAdsenseBot, GoogleBot و 3 زوار
