تحسين عناوين الصفحة
الوداع يا phpBB الى الابد.
حساب تجريبي
test
123456
حساب تجريبي
test
123456
?? ??? ?? ????? ??? ?? ??? install
حساب تجريبي
test
123456
حساب تجريبي
test
123456
???? ????? ????? ???? ??? install_mod.xml
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<?xml-stylesheet type="text/xsl" href="modx.prosilver.ar.xsl"?>
<!--NOTICE: Please open this file in your web browser. If presented with a security warning, you may safely tell it to allow the blocked content.-->
<!--For security purposes, please check: http://www.phpbb.com/mods/ for the latest version of this MOD.\nAlthough MODs are checked before being allowed in the MODs Database there is no guarantee that there are no security problems within the MOD.\nNo support will be given for MODs not found within the MODs Database which can be found at http://www.phpbb.com/mods/-->
<mod xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.phpbb.com/mods/xml/modx-1.2.5.xsd">
<header>
<meta name="generator" content="MODX file generated with PP MODX Creator by tumba25 (offline version)"/>
<license><![CDATA[http://opensource.org/licenses/gpl-license.php GNU General Public License v2]]></license>
<title lang="ar"><![CDATA[????? ?????? ??????]]></title>
<description lang="ar"><![CDATA[???? ??? ????? ?????? ?????? ?????? ?? ???? ??????? , ???? ???? ??? ??????? ?? ??????? ??? ??? ???????. ??? ??????? ???? ????? ??? ???? ?? ???? ?? ????? ??????? ???? , ?? ????? ???? ????? ????? ??????? ?????? ?????? ?????. ???????? ???? : ??? ??????? ?? ??????? - ??? ??????? ( ????? ?? : ??????? ??????? / ??????? - ??? ??????? ).]]></description>
<author-group>
<author>
<realname><![CDATA[Michael C.]]></realname>
<username><![CDATA[Unknown Bliss]]></username>
<homepage><![CDATA[http://sa007.cz.cc]]></homepage>
<email><![CDATA[sa.chelsea@live.co.uk]]></email>
</author>
<author>
<realname>???? ??????</realname>
<email>mods@al-yemen.de</email>
<arusername>A.B.M.K</arusername>
<homepage>http://al-yemen.de/mods</homepage>
<contributions-group>
<contributions status="current" position="??????? ?????" />
</contributions-group>
</author>
</author-group>
<mod-version>1.0.2</mod-version>
<installation>
<level>easy</level>
<time>120</time>
<target-version>3.0.7-PL1</target-version>
</installation>
<history>
<entry>
<date>2010-05-22</date>
<rev-version>0.0.1</rev-version>
<changelog lang="ar">
<change><![CDATA[MODX and Root Created]]></change>
</changelog>
</entry>
<entry>
<rev-version>0.0.2</rev-version>
<change><![CDATA[Added edits]]></change>
</changelog>
</entry>
<entry>
<date>2010-05-23</date>
<rev-version>1.0.0</rev-version>
<change><![CDATA[Fixed a typo in the viewtopic.php file]]></change>
</changelog>
</entry>
<entry>
<date>2010-07-08</date>
<rev-version>1.0.1</rev-version>
<change><![CDATA[Edited Edits]]></change>
</changelog>
</entry>
<entry>
<date>2010-08-25</date>
<rev-version>1.0.2</rev-version>
<change><![CDATA[Adding Subsilver]]></change>
</changelog>
</entry>
</history>
<link-group>
<link type="template" href="./contrib/subsilver2.xml" lang="ar">?????? Subsilver</link>
</link-group>
</header>
<action-group>
<open src="viewforum.php">
<edit>
<find><![CDATA[page_header($user->lang['VIEW_FORUM'] . ' - ' . $forum_data['forum_name'], true, $forum_id); ]]></find>
<action type="replace-with"><![CDATA[page_header($forum_data['forum_name'], true, $forum_id); ]]></action>
</edit>
</open>
<open src="viewtopic.php">
<edit>
<find><![CDATA[page_header($user->lang['VIEW_TOPIC'] . ' - ' . $topic_data['topic_title'], true, $forum_id); ]]></find>
<action type="replace-with"><![CDATA[page_header($topic_data['topic_title'], true, $forum_id);]]></action>
</edit>
</open>
<open src="styles/prosilver/template/overall_header.html">
<edit>
<find><![CDATA[<title>{SITENAME} • <!-- IF S_IN_MCP -->{L_MCP} • <!-- ELSEIF S_IN_UCP -->{L_UCP} • <!-- ENDIF -->{PAGE_TITLE}</title>]]></find>
<action type="replace-with"><![CDATA[<title>{PAGE_TITLE} • <!-- IF S_IN_MCP -->{L_MCP} • <!-- ELSEIF S_IN_UCP -->{L_UCP} • <!-- ENDIF -->{SITENAME}</title>]]></action>
</edit>
</open>
<diy-instructions lang="ar"><![CDATA[??? ???? ??? ??????? ??????? ?? ???? ?????? ????????.]]></diy-instructions>
</action-group>
</mod>
حساب تجريبي
test
123456
حساب تجريبي
test
123456
ليس للقوة حدود ولكن هناك قواعد
http://asrclub.net/php احصل علي منتدي مجاني
