سؤال للمحترفين فى التصميم والتحويل
mohager444
مشاركات: 45
اشترك في: الجمعة يناير 21, 2011 6:21 pm
مشاركةبواسطة mohager444 » الخميس إبريل 07, 2011 10:25 pm
???? ??? ?????? ????? ?????? ???? ?? ???? ????? ????? ????? ?????? ??? ?? ??? ????? ???? ????? ??? ???? Vb
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="{S_CONTENT_DIRECTION}" lang="{S_USER_LANG}" xml:lang="{S_USER_LANG}">
<head>
<meta http-equiv="content-type" content="text/html; charset={S_CONTENT_ENCODING}" />
<meta http-equiv="content-language" content="{S_USER_LANG}" />
<meta http-equiv="content-style-type" content="text/css" />
<meta http-equiv="imagetoolbar" content="no" />
<meta name="resource-type" content="document" />
<meta name="distribution" content="global" />
<meta name="copyright" content="2000, 2002, 2005, 2007 phpBB Group" />
<meta name="keywords" content="" />
<meta name="description" content="" />
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
{META}
<title>{SITENAME} • <!-- IF S_IN_MCP -->{L_MCP} • <!-- ELSEIF S_IN_UCP -->{L_UCP} • <!-- ENDIF -->{PAGE_TITLE}</title>
<!-- IF S_ENABLE_FEEDS -->
	<!-- IF S_ENABLE_FEEDS_OVERALL --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {SITENAME}" href="{U_FEED}" /><!-- ENDIF -->
	<!-- IF S_ENABLE_FEEDS_NEWS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FEED_NEWS}" href="{U_FEED}?mode=news" /><!-- ENDIF -->
	<!-- IF S_ENABLE_FEEDS_FORUMS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_ALL_FORUMS}" href="{U_FEED}?mode=forums" /><!-- ENDIF -->
	<!-- IF S_ENABLE_FEEDS_TOPICS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FEED_TOPICS_NEW}" href="{U_FEED}?mode=topics" /><!-- ENDIF -->
	<!-- IF S_ENABLE_FEEDS_TOPICS_ACTIVE --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FEED_TOPICS_ACTIVE}" href="{U_FEED}?mode=topics_active" /><!-- ENDIF -->
	<!-- IF S_ENABLE_FEEDS_FORUM and S_FORUM_ID --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_FORUM} - {FORUM_NAME}" href="{U_FEED}?f={S_FORUM_ID}" /><!-- ENDIF -->
	<!-- IF S_ENABLE_FEEDS_TOPIC and S_TOPIC_ID --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_TOPIC} - {TOPIC_TITLE}" href="{U_FEED}?f={S_FORUM_ID}&t={S_TOPIC_ID}" /><!-- ENDIF -->
<![if !IE]>
<style type="text/css">
fieldset{
border-width:1px;
border-color:#dedede;
border-style:solid;
padding:5px;
-moz-border-radius:7px;
-webkit-border-radius:7px;
</style>
<![endif]>
<link rel="stylesheet" href="{T_STYLESHEET_LINK}" type="text/css" />
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
	if ({S_NEW_PM})
		popup('{UA_POPUP_PM}', 400, 225, '_phpbbprivmsg');
function popup(url, width, height, name)
	if (!name)
		name = '_popup';
	window.open(url.replace(/&/g, '&'), name, 'height=' + height + ',resizable=yes,scrollbars=yes,width=' + width);
	return false;
function jumpto()
	var page = prompt('{LA_JUMP_PAGE}:', '{ON_PAGE}');
	var per_page = '{PER_PAGE}';
	var base_url = '{A_BASE_URL}';
	if (page !== null && !isNaN(page) && page == Math.floor(page) && page > 0)
		if (base_url.indexOf('?') == -1)
			document.location.href = base_url + '?start=' + ((page - 1) * per_page);
			document.location.href = base_url.replace(/&/g, '&') + '&start=' + ((page - 1) * per_page);
* Find a member
function find_username(url)
	popup(url, 760, 570, '_usersearch');
	return false;
* Mark/unmark checklist
* id = ID of parent container, name = name prefix, state = state [true/false]
function marklist(id, name, state)
	var parent = document.getElementById(id);
	if (!parent)
		eval('parent = document.' + id);
	if (!parent)
		return;
	var rb = parent.getElementsByTagName('input');
	for (var r = 0; r < rb.length; r++)
		if (rb[r].name.substr(0, name.length) == name)
			rb[r].checked = state;
<!-- IF ._file -->
	* Play quicktime file by determining it's width/height
	* from the displayed rectangle area
	* Only defined if there is a file block present.
	function play_qt_file(obj)
		var rectangle = obj.GetRectangle();
		if (rectangle)
			rectangle = rectangle.split(',')
			var x1 = parseInt(rectangle[0]);
			var x2 = parseInt(rectangle[2]);
			var y1 = parseInt(rectangle[1]);
			var y2 = parseInt(rectangle[3]);
			var width = (x1 < 0) ? (x1 * -1) + x2 : x2 - x1;
			var height = (y1 < 0) ? (y1 * -1) + y2 : y2 - y1;
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.height = height + 16;
		obj.SetControllerVisible(true);
		obj.Play();
</script>
</head>
<body class="{S_CONTENT_DIRECTION}">
<a name="top"></a>
<table id="toptable" cellpadding="0" border="0" cellspacing="0.0" dir="rtl">
    <td><img alt=" " src="{T_THEME_PATH}/images/bbd_0_4.jpg" style="width: 10px;  height: 173px; border-width: 0px;"></td>
    <td colspan="3" background="{T_THEME_PATH}/images/bbd_0_1.jpg" width="100%"><div align="center"><a href="{U_INDEX}"><img alt=" " src="{T_THEME_PATH}/images/bbd_0_2.jpg" style="width: 434px;  height: 173px; border-width: 0px;"></a>
</div></td>
    <td><img alt=" " src="{T_THEME_PATH}/images/bbd_0_0.jpg" style="width: 9px;  height: 173px; border-width: 0px;"></td>
    <td background="{T_THEME_PATH}/images/bbd_2_4.jpg" width="10px"></td>
    <td colspan="3" background="{T_THEME_PATH}/images/bbd_3_1.jpg" style="text-align:center">
<fieldset><legend>???????</legend>
<!-- INCLUDE ads.html --></fieldset>
    <td background="{T_THEME_PATH}/images/bbd_2_0.jpg" width="9px"></td>
    <td colspan="3" background="{T_THEME_PATH}/images/bbd_3_1.jpg" height="41px">
<div class="allbg">
<div id="logintop">
<fieldset><legend>{L_LOGIN}</legend>
	<form method="post" action="{S_LOGIN_ACTION}">
	<span class="genmed">{L_USERNAME}:</span><input class="post" type="text" name="username" size="10" style="background:transparent;" />
<span class="genmed">{L_PASSWORD}:</span><input class="post" type="password" name="password" size="10" style="background:transparent;" />
<!-- IF S_AUTOLOGIN_ENABLED --> <span class="gensmall">{L_LOG_ME_IN}</span> <input type="checkbox" class="radio" name="autologin" /><!-- ENDIF -->
<input type="submit" class="btnmain" name="login" value="????" style="background:transparent;"/>
	{S_FORM_TOKEN}
	{S_LOGIN_REDIRECT}
</fieldset>
	</form>
<!-- IF  S_USER_LOGGED_IN -->
<div id="logintop2">
<fieldset><legend>???? ?????</legend>
        ???? ????? ?? {LAST_VISIT_DATE}
<br />
<!-- IF S_DISPLAY_PM -->  <a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a><!-- ENDIF -->  |
<!-- IF not S_IS_BOT --><a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a> <!-- ENDIF --> |
<!-- IF S_USER_LOGGED_IN -->  <a href="{U_PROFILE}"> {L_PROFILE}</a><!-- ENDIF --> |
<!-- IF U_MCP -->
		[ <a href="{U_MCP}">{L_MCP}</a> ]
</legend>
    <td colspan="3" background="{T_THEME_PATH}/images/bbd_2_1.jpg" height="41px">
<div id="menubar">
			<td class="genmed">
				<!-- IF U_RESTORE_PERMISSIONS -->  <a href="{U_RESTORE_PERMISSIONS}"> {L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
				<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN -->  <span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
<span ><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a> | <a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></span>
					<!-- ELSEIF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) -->  <a href="{U_REGISTER}"> {L_REGISTER}</a>
<td><div id="ctime">{CURRENT_TIME}</div></td>
			<td class="genmed" align="{S_CONTENT_FLOW_END}">
				<a href="{U_FAQ}"> {L_FAQ}</a>
				<!-- IF S_DISPLAY_SEARCH -->   <a href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
					<!-- IF S_DISPLAY_MEMBERLIST -->   <a href="{U_MEMBERLIST}"> {L_MEMBERLIST}</a><!-- ENDIF -->
    <td colspan="3" background="{T_THEME_PATH}/images/bbd_3_1.jpg">
<div id="wrapcentre">
	<p class="searchbar">
		<span style="float: {S_CONTENT_FLOW_BEGIN};"><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a> | <a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a></span>
	</p>
	<br style="clear: both;" />
	<!-- INCLUDE breadcrumbs.html -->
	<br />
مشاركات: 942
مشاركةبواسطة Dawn birth » الجمعة إبريل 08, 2011 7:05 pm
?????? ??? ??? ?? ???? ????? ????? ??? ?????? ???? ?? ???? ????? ????? ????? ?? ?? ??? phpBB ??? ?? ?????? ????? ????? ????? ???????? ?? ????? ? ???? ??? ?????? ?? ?????? ?? ???? ?? ???? ????? ???? ????? ????? ????? ??? ?? ??. ??? ?? ???? ?? ????? ???? ?? ??? ? ??? ?? ?? ?? ????? ?? ?? ???? ??? ???? ??? html,css ??? ???? ??? ????? ????? ???? ??? ??????? ??? ?????? ????? ? ??? ???? ?????.
mohager444
مشاركات: 45
مشاركةبواسطة mohager444 » الجمعة إبريل 08, 2011 11:02 pm
mohager444
مشاركات: 45
مشاركةبواسطة mohager444 » الجمعة إبريل 08, 2011 11:03 pm
