هل منتديات phpbb3 تحتاج لسيرفر خاص
?? ??????? phpbb3 ????? ?????? ???
??? ?????? ???? ????????? ???? ??? ????? ?? ??????? phpbb3 ?? ???? ??? ??????? ??? ????? ???? php ?mysql ?? ?? ????? ???? ??? ????? ?????? ??? ???? ????????? ???? ???????
Requirements
phpBB3 has a few requirements which must be met before you are able to install and use it.
A webserver or web hosting account running on any major Operating System with support for PHP
A SQL database system, one of:
MySQL 3.23 or above (MySQLi supported)
PostgreSQL 7.3+
SQLite 2.8.2+
Firebird 2.1+
MS SQL Server 2000 or above (directly or via ODBC)
Oracle
PHP 4.3.3+ (>=4.3.3, >4.4.x, >5.x.x, >6.0-dev (compatible)) with support for the database you intend to use.
getimagesize() function need to be enabled.
These optional presence of the following modules within PHP will provide access to additional features, but they are not required.
zlib Compression support
Remote FTP support
XML support
Imagemagick support
GD Support
If your server or hosting account does not meet the requirements above we are afraid phpBB3 is not for you.
