تعديل روابط المواضيع و الردود
محمود محمد
مشاركات: 15
اشترك في: الثلاثاء يناير 22, 2013 1:12 pm
مشاركةبواسطة محمود محمد » الجمعة مايو 31, 2013 6:16 pm
??? ?????? ????? ?????? ?????? ??? "nofollow" ??????? ???????? ? "dofollow" ??????? ???????? ? ????????? ?????? ????? ?????
// BEGIN nofollow
    // February 5th, 2010 By Liv Jones
    //www.extra-pc.com/vb
    // *Custom Variables:
       // If your server variable isn't set you may need to replace
       // this line with an example such as:
       // $home_url=greensboring.com;
       $home_url=$_SERVER['HTTP_HOST'];
    // *Option Custom Variables:
       $short_list=array(
       'www.extra-pc.com',
       'www.phpbbarabia.com',
       'www.phpbb.com',
        $follow_fp='disable';
    // ************ CHANGE NOTHING BELOW HERE ****************
    // Make all the links the same format regardless of url tag
    $message = preg_replace('/(a class="postlink" href="(.*?)")/','a href="$2" class="postlink"',$message);
    // replace all links with nofollow
    $message = preg_replace('/(class="postlink")/','class="postlink" rel="nofollow" onclick="window.open(this.href);return false;"',$message);
    // parse out local links to remove nofollow
    $message = preg_replace('/(a href="http:\/\/'.$home_url.'(.*?)" class="postlink" rel="nofollow" onclick="window.open\(this.href\)\;return false\;")/','a href="http://'.$home_url.'$2" class="postlink-local"',$message);
// DoFollow on First Post only like a blog
    if (($row['post_id'] == $topic_data['topic_first_post_id']) && ($follow_fp != 'disable') && ($user_cache[$poster_id]['posts'] > 3)) {
    $message = preg_replace('/(rel="nofollow")/','',$message);
    // Licensing
    $message = preg_replace(base64_decode('LyBHcmVlbnNib3JvIC8='),base64_decode('PGEgaHJlZj0iaHR0cDovL2dyZWVuc2JvcmluZy5jb20vIj4gR3JlZW5zYm9ybyA8L2E+'),$message);
    // Optional WhiteList for dofollowing
    // (But still open in new window)
    foreach($short_list as $sl) {
    $message = preg_replace('/(href="http:\/\/'.$sl.'(.*?)" class="postlink" rel="nofollow")/','href="http://'.$sl.'$2" class="postlink" rel="dofollow"',$message);
    // Parsing Image Sizes
    if ($row['post_id'] == $topic_data['topic_first_post_id']) {
    $message = preg_replace('/(alt="Image")/','alt="Image" style="max-width:400px;"',$message); } else {
    $message = preg_replace('/(alt="Image")/','alt="Image" style="max-width:650px;"',$message); }
    // END - nofollow
http://www.phpbbarabia.com/community/vi ... 44&t=36695
<!-- IF not S_IS_BOT -->
????? ??? - ????? ???? ???? ???? ?????? ???? ??? ????? ?????? http ?? https ??? ??? ????? ?? ???? ??? ??????? ??????? ??? ??????? ?? ????? ?????? https
*.google.com
mail.google.com
محمود محمد
مشاركات: 15
مشاركةبواسطة محمود محمد » الاثنين يونيو 03, 2013 7:47 pm
???????? ????? ?? ???? ????? <==(????) :roll:
المتصفحون للمنتدى الآن: Ahrefs [Bot] وزائران
