هل يوجد اضافة لتعديل روابط المشاركات
- Mohammad Sy
- مشاركات: 76
- اشترك في: الخميس يوليو 09, 2015 12:12 pm
http://www.phpbbarabia.com/community/viewtopic.php?f=113&t=42392
Re: ?? ???? ????? ?????? ????? ?????????
????? ????? ??? tiaar
http://www.phpbbarabia.com/community/vi ... 95#p224123
- Mohammad Sy
- مشاركات: 76
- مشاركات: 21
- اشترك في: السبت مايو 09, 2015 9:20 am
phpBB SEO Ultimate SEO URL
http://anaher.eb2a.com/book3
http://anaher.eb2a.com/book3/topic-t20.html
1/ ???? ??????? ??????? ????? ???????? ext ??? ??????? ??? ????? ????.
2/ ???? ??? .htaccess ??? ????? ????? ?? ??????? ??????? ???? ??????? ???? ?? ???? :
3/ ???? ???? ???????? ????? :
???? ????? ???? ?? ???? ?????? ???? phpbb seo
4/ ???? ???????? ?????? :
5/ ??
6/
??? ????? ????????? ?????? ??? ??? ????? ?????? phpbb3.1
<IfModule mod_rewrite.c>
# You may need to un-comment the following lines
# Options +FollowSymlinks
# To make sure that rewritten dir or file (/|.html) will not load dir.php in case it exist
# Options -MultiViews
# REMEBER YOU ONLY NEED TO STARD MOD REWRITE ONCE
RewriteEngine On
# Uncomment the statement below if you want to make use of
# HTTP authentication and it does not already work.
# This could be required if you are for example using PHP via Apache CGI.
# RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
# REWRITE BASE
RewriteBase /
# HERE IS A GOOD PLACE TO FORCE CANONICAL DOMAIN
# Define fully qualified ssl aware protocol
# RewriteCond %{SERVER_PORT}s ^(443(s)|[0-9]+s)$
# RewriteRule ^.*$ - [env=HttpFullProto:http%2://]
# RewriteCond %{HTTP_HOST} !^anaher\.eb2a\.com$ [NC]
# RewriteRule ^(.*)$ %{ENV:HttpFullProto}anaher.eb2a.com/$1 [QSA,L,R=301]
# DO NOT GO FURTHER IF THE REQUESTED FILE / DIR DOES EXISTS
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule . - [L]
# FORUM INDEX REWRITERULE WOULD STAND HERE IF USED. "forum" REQUIRES TO BE SET AS FORUM INDEX
# RewriteRule ^forum\.html$ /index.php [QSA,L,NC]
# FORUM ALL MODES
RewriteRule ^(forum|[a-z0-9_-]*-f)([0-9]+)/?(page([0-9]+)\.html)?$ /viewforum.php?f=$2&start=$4 [QSA,L,NC]
# TOPIC WITH VIRTUAL FOLDER ALL MODES
RewriteRule ^(forum|[a-z0-9_-]*-f)([0-9]+)/(topic|[a-z0-9_-]*-t)([0-9]+)(-([0-9]+))?\.html$ /viewtopic.php?f=$2&t=$4&start=$6 [QSA,L,NC]
# TOPIC WITHOUT FORUM ID & DELIM ALL MODES
RewriteRule ^([a-z0-9_-]*)/?(topic|[a-z0-9_-]*-t)([0-9]+)(-([0-9]+))?\.html$ /viewtopic.php?forum_uri=$1&t=$3&start=$5 [QSA,L,NC]
# PROFILES ALL MODES WITH ID
RewriteRule ^(member|[a-z0-9_-]*-u)([0-9]+)/?$ /memberlist.php?mode=viewprofile&u=$2 [QSA,L,NC]
# USER MESSAGES ALL MODES WITH ID
RewriteRule ^(member|[a-z0-9_-]*-u)([0-9]+)/(topics|posts)/?(page([0-9]+)\.html)?$ /search.php?author_id=$2&sr=$3&start=$5 [QSA,L,NC]
# GROUPS ALL MODES
RewriteRule ^(group|[a-z0-9_-]*-g)([0-9]+)(-([0-9]+))?\.html$ /memberlist.php?mode=group&g=$2&start=$4 [QSA,L,NC]
# POSTS
RewriteRule ^post([0-9]+)\.html$ /viewtopic.php?p=$1 [QSA,L,NC]
# ACTIVE TOPICS
RewriteRule ^active-topics(-([0-9]+))?\.html$ /search.php?search_id=active_topics&start=$2&sr=topics [QSA,L,NC]
# UNANSWERED TOPICS
RewriteRule ^unanswered(-([0-9]+))?\.html$ /search.php?search_id=unanswered&start=$2&sr=topics [QSA,L,NC]
# NEW POSTS
RewriteRule ^newposts(-([0-9]+))?\.html$ /search.php?search_id=newposts&start=$2&sr=topics [QSA,L,NC]
# UNREAD POSTS
RewriteRule ^unreadposts(-([0-9]+))?\.html$ /search.php?search_id=unreadposts&start=$2 [QSA,L,NC]
# THE TEAM
RewriteRule ^the-team\.html$ /memberlist.php?mode=team [QSA,L,NC]
# HERE IS A GOOD PLACE TO ADD OTHER PHPBB RELATED REWRITERULES
# FORUM WITHOUT ID & DELIM ALL MODES
# THESE LINES MUST BE LOCATED AT THE END OF YOUR HTACCESS TO WORK PROPERLY
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^([a-z0-9_-]+)/?(page([0-9]+)\.html)?$ /viewforum.php?forum_uri=$1&start=$3 [QSA,L,NC]
# FIX RELATIVE PATHS : FILES
RewriteRule ^(style\.php|ucp\.php|mcp\.php|faq\.php|posting\.php|download/file\.php|report\.php|adm/index\.php|cron\.php)$ /$1 [QSA,L,NC,R=301]
# FIX RELATIVE PATHS : IMAGES
RewriteRule ^(styles/.*|images/.*|assets/.*|ext/.*)$ /$1 [QSA,L,NC,R=301]
# The following 3 lines will rewrite URLs passed through the front controller
# to not require app.php in the actual URL. In other words, a controller is
# by default accessed at /app.php/my/controller, but can also be accessed at
# /my/controller
RewriteRule ^(.*)$ /app.php [QSA,L]
</IfModule>
# With Apache 2.4 the "Order, Deny" syntax has been deprecated and moved from
# module mod_authz_host to a new module called mod_access_compat (which may be
# disabled) and a new "Require" syntax has been introduced to mod_authz_host.
# We could just conditionally provide both versions, but unfortunately Apache
# does not explicitly tell us its version if the module mod_version is not
# available. In this case, we check for the availability of module
# mod_authz_core (which should be on 2.4 or higher only) as a best guess.
<IfModule mod_version.c>
<IfVersion < 2.4>
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
</IfVersion>
<IfVersion >= 2.4>
Require all denied
</Files>
Require all denied
</Files>
</IfVersion>
</IfModule>
<IfModule !mod_version.c>
<IfModule !mod_authz_core.c>
Order Allow,Deny
Deny from All
</Files>
Order Allow,Deny
Deny from All
</Files>
</IfModule>
<IfModule mod_authz_core.c>
Require all denied
</Files>
Require all denied
</Files>
</IfModule>
</IfModule>
5/ ??
6/
آخر تعديل بواسطة حذيفة احمد في الخميس يوليو 23, 2015 2:34 pm، تم التعديل 3 مرات في المجمل.
- Mohammad Sy
- مشاركات: 76
2/ ???? ??? .htacess ??? ????? ????? ?? ??????? ??????? ???? ??????? ???? ?? ???? :
- Mohammad Sy
- مشاركات: 76
Not Found
The requested URL /forum.html was not found on this server.
Apache/2.4.9 (Win32) PHP/5.5.12 Server at localhost Port 80
Not Found
- مشاركات: 21
- htaccess.zip
- (2.01 KiB) حُمِّل 534 مرةً
- مشاركات: 21
?????? ??????? ?????? ???? ?????? ????? .htaccessMohammad Sy كتب:?????? ??????? ??? ???? ??? ??????
Not Found
- Mohammad Sy
- مشاركات: 76
- مشاركات: 21
????alhitary كتب:????? ?? ?????
