طريقة إضافة ملاحظات عند التسجيل
- قيس الرفاعي
- مشاركات: 2
- اشترك في: الثلاثاء مايو 24, 2016 11:23 pm
Re: ????? ????? ??????? ??? ???????
???? ??? ???? ??????? ???????? ( styles\prosilver\template )
????? ????? ucp_register.html
??? ??????? ???? ??????? ??? : Notepad++ ?? ??????? ??? ?????
<!-- IF L_REG_COND -->
<dl><dd><strong>{L_REG_COND}</strong></dd></dl>
<!-- ENDIF -->كود: تحديد الكل
<dl><dd class="error"><strong>?????? ???? : ??? ?? ??? ????? ????? ??????? ?? ????? ????? , ??????? ?? ????? ??????? ????? ????? ???</strong></dd></dl>??? ??????? ???? ??????? ??? : Notepad++ ?? ??????? ??? ?????
- قيس الرفاعي
- مشاركات: 2
// <![CDATA[
* Change language
function change_language(lang_iso)
document.cookie = '{COOKIE_NAME}_lang=' + lang_iso + '; path={COOKIE_PATH}';
document.forms['register'].change_lang.value = lang_iso;
document.forms['register'].submit.click();
</script>
<form id="register" method="post" action="{S_UCP_ACTION}"{S_FORM_ENCTYPE}>
<div class="panel">
<div class="inner">
<h2>{SITENAME} - {L_REGISTRATION}</h2>
<fieldset class="fields2">
<!-- IF ERROR --><dl><dd class="error">{ERROR}</dd></dl><!-- ENDIF -->
<!-- EVENT ucp_register_credentials_before -->
<dl>
<dt><label for="username">{L_USERNAME}{L_COLON}</label><br /><span>{L_USERNAME_EXPLAIN}</span></dt>
<dd><input type="text" tabindex="1" name="username" id="username" size="25" value="{USERNAME}" class="inputbox autowidth" title="{L_USERNAME}" /></dd>
</dl>
<dl>
<dt><label for="email">{L_EMAIL_ADDRESS}{L_COLON}</label></dt>
<dd><input type="email" tabindex="2" name="email" id="email" size="25" maxlength="100" value="{EMAIL}" class="inputbox autowidth" title="{L_EMAIL_ADDRESS}" autocomplete="off" /></dd>
</dl>
<dl>
<dt><label for="new_password">{L_PASSWORD}{L_COLON}</label><br /><span>{L_PASSWORD_EXPLAIN}</span></dt>
<dd><input type="password" tabindex="4" name="new_password" id="new_password" size="25" value="{PASSWORD}" class="inputbox autowidth" title="{L_NEW_PASSWORD}" autocomplete="off" /></dd>
</dl>
<dl>
<dt><label for="password_confirm">{L_CONFIRM_PASSWORD}{L_COLON}</label></dt>
<dd><input type="password" tabindex="5" name="password_confirm" id="password_confirm" size="25" value="{PASSWORD_CONFIRM}" class="inputbox autowidth" title="{L_CONFIRM_PASSWORD}" autocomplete="off" /></dd>
</dl>
<!-- EVENT ucp_register_credentials_after -->
<hr />
<!-- EVENT ucp_register_options_before -->
<dl>
<dt><label for="lang">{L_LANGUAGE}{L_COLON}</label></dt>
<dd><select name="lang" id="lang" onchange="change_language(this.value); return false;" tabindex="6" title="{L_LANGUAGE}">{S_LANG_OPTIONS}</select></dd>
</dl>
<!-- INCLUDE timezone_option.html -->
<!-- EVENT ucp_register_profile_fields_before -->
<!-- IF .profile_fields -->
<dl><dd><strong>{L_ITEMS_REQUIRED}</strong></dd></dl>
<!-- BEGIN profile_fields -->
<dl>
<dt><label<!-- IF profile_fields.FIELD_ID --> for="{profile_fields.FIELD_ID}"<!-- ENDIF -->>{profile_fields.LANG_NAME}{L_COLON}<!-- IF profile_fields.S_REQUIRED --> *<!-- ENDIF --></label>
<!-- IF profile_fields.LANG_EXPLAIN --><br /><span>{profile_fields.LANG_EXPLAIN}</span><!-- ENDIF -->
<!-- IF profile_fields.ERROR --><br /><span class="error">{profile_fields.ERROR}</span><!-- ENDIF --></dt>
<dd>{profile_fields.FIELD}</dd>
</dl>
<!-- END profile_fields -->
<!-- EVENT ucp_register_profile_fields_after -->
</fieldset>
<!-- IF CAPTCHA_TEMPLATE -->
<!-- DEFINE $CAPTCHA_TAB_INDEX = 8 -->
<!-- INCLUDE {CAPTCHA_TEMPLATE} -->
<!-- IF S_COPPA -->
<div class="panel">
<div class="inner">
<h4>{L_COPPA_COMPLIANCE}</h4>
<p>{L_COPPA_EXPLAIN}</p>
<div class="panel">
<div class="inner">
<fieldset class="submit-buttons">
{S_HIDDEN_FIELDS}
<input type="reset" value="{L_RESET}" name="reset" class="button2" />
<input type="submit" tabindex="9" name="submit" id="submit" value="{L_SUBMIT}" class="button1 default-submit-action" />
{S_FORM_TOKEN}
</fieldset>
</form>
<!-- INCLUDE overall_footer.html -->
<!-- ENDIF -->ظروف الحرب في بلادي سبب عدم القدرة على الرد والمُتابعة كما تحبون... فسامحوني
